T56 guru's step inside
Old Jun 28, 2014 | 08:15 PM
backnblack2003z06's Avatar
backnblack2003z06
Default T56 guru's step inside
I broke my rear diff at the track a few weeks ago which in turn took out the mainshaft in the trans. I pulled the transmision apart the other day to repalce the mainshaft and also found the 5/6/reverse shift shaft was bent just slightly were it goes into the front plate. The car always shifted fine before the track breakage, and I don't see any way this could be related to that. Anyone run into this or have any ideas what could have caused it? Other than the 2 shafts the trans is 100% perfect.
