Water Leak driver side
Old Jul 24, 2002 | 10:00 AM
RockeVette95's Avatar
RockeVette95
Default Water Leak driver side
This only occurs when my car is washed in my driveway nose pointed up.
Water leaks in on driver's side, when I pull the car up level water pours from the driver knee bolster ??? any ideas, has this happened to anyone else? Car is usually in the garage when it rains so I really don't know if water would enter during "normal conditions"
Old Jul 24, 2002 | 10:30 AM
C5 Chet's Avatar
C5 Chet
Default Re: Water Leak driver side (RockeVette95)
I have has a '98 and an '02. I have several friends with C5s.
They all leak at some point or another.
I have had the windows adjusted by the dealer three times now.
Everytime I change the roof panel another wind noise or water
leak pops up and the car is brand new.
I believe adjusting the windows is the only answer but not sure.
Chet
Old Jul 24, 2002 | 10:41 AM
carpe dm's Avatar
carpe dm
What do you mean by "knee bolster?" The seat? :confused:
Old Jul 24, 2002 | 12:30 PM
RockeVette95
Default Re: Water Leak driver side (carpe dm)
Picture in your mind the area under the steering wheel where your knees would hit in an accident.
Old Jul 24, 2002 | 01:44 PM
white top's Avatar
white top
Just a thought is water getting into air intake at the cowl drivers side just forward of the rear edge of the hood. If water gets in there it should drain out bottom of car drivers side.Try it pour some water in there should drain immediately if its not blocked.
Old Jul 25, 2002 | 09:18 AM
RockeVette95
No water leak guru's out there?
To Water Leak driver side
