99 c5 ac poor venting & weak
Old Jul 1, 2014 | 10:10 PM
C5 NEED FOR SPEED's Avatar
C5 NEED FOR SPEED
Default 99 c5 ac poor venting & weak
Having a problem with the AC venting on my 99 C5 Convertible.Not blowing very strong.Cold but not strong.When on Max, the fan seems like it is on a lower setting.Concluding one of the venting doors not working properly, possibly the vac line that requires access by removing the RH inner fender and replacing the line ? Can someone please direct me to a thread with some detailed info on possible causes and fixes ? Or offer some tips ? Thanks for your help in advance.Much appreciated.Getting hot out there and I need some AC LOL !!
Old Jul 2, 2014 | 10:02 AM
Lt. Dan M.'s Avatar
Lt. Dan M.
Have you checked for any HVAC codes? If you have codes try resetting them, write them down first though. If you don't have any codes you might try disconnecting the - battery lead for a few seconds. The mix doors will then go to full open and full closed to relearn their stops. My 99 gave me fits for a while. Ended up taking the whole dash apart just to find that the mix doors were working fine.
Old Jul 2, 2014 | 03:32 PM
C5 NEED FOR SPEED
I did diconnect the battery and it still not working right.I will check for the codes.THANKS
Old Jul 2, 2014 | 05:25 PM
T_Vert's Avatar
T_Vert
Is it not blowing strong out of the vents but ok out of defrost? If so the vacuum hose at the back of the intake came off.
Dave
Old Jul 3, 2014 | 12:55 AM
BigGun's Avatar
BigGun
Can you control the fan speed from the dash or will it just run one speed?
Old Jul 3, 2014 | 09:03 AM
dadaroo's Avatar
dadaroo
You MUST do it this way if recalibrating is truly the problem:
Re-Calibrating Actuators-----
Use the following steps to perform the calibration update:
1. Turn OFF the ignition.
2. Remove the battery positive voltage circuit fuse of the HVAC Control Module (fuse #27).
Important
The module memory will not clear if the battery positive voltage circuit fuse is installed in less than 60 seconds.
3. Wait 60 seconds.
4. Install the fuse.
I have heard some people have had to do it several times to have it "take".
Old Jul 3, 2014 | 09:58 AM
bjones7131's Avatar
bjones7131
Is this fuse 27 under the hood or footwell? I need to remember this!!!
Old Jul 3, 2014 | 11:32 AM
Corvette Don's Avatar
Corvette Don
As stated, pull codes before doing anything else...
Old Jul 3, 2014 | 12:50 PM
C5 NEED FOR SPEED
Thanks for the advice.First thing I thought of was checking the vac line on the intake ? I am not sure but I will check again, but thought that the flow was not working on defog mode.Will chek fuses too.
Old Jul 4, 2014 | 06:59 AM
dadaroo's Avatar
dadaroo
Yes, in the I/P fuse box.
To 99 c5 ac poor venting & weak
