yella terra rocker install
Old Jul 10, 2014 | 07:49 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
Default yella terra rocker install
i will be installing the 1.7 rockers along with ls2 valve springs and trick flow pushrods this sunday. i will be taking pictures along the way.
Old Jul 10, 2014 | 07:51 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
can't wait
Old Jul 12, 2014 | 06:33 AM
mrr23's Avatar
mrr23
St. Jude Donor '15
The pushrods and cheesy dual valve spring tool from eBay.
Old Jul 12, 2014 | 11:38 AM
reactor2's Avatar
reactor2
Take a look at this installation video:
http://m.youtube.com/watch?v=xYuZa2F0ZpM
If you are running an aftermarket cam you may need to utilize the supplied shims.
Also, don't use their torquing method, rather make sure each cylinder is TDC on the compression stroke.
Even without using the shims you may want to verify your pushrod length. When I test fit mine I had about .020" less preload. If you use the shims you will definitely need longer pushrods.
Old Jul 12, 2014 | 01:06 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
stock cam.
Old Jul 12, 2014 | 04:47 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
good thing i'm doing this.
Old Jul 12, 2014 | 09:37 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
here's the pushrod. head has very slight wear inside the pushrod hole.
Old Jul 12, 2014 | 09:45 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
some pics of progress
covers removed
passenger side coil pack removed
driver's side coil pack
the hard to reach driver's coil pack bolt behind the alternator. used a 10mm gear wrench
removing driver's #1 spark plug
driver's side rockers
Old Jul 12, 2014 | 09:47 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
the fun begins tomorrow. R&R the springs
rockers soaking in oil
Old Jul 13, 2014 | 11:43 AM
mrr23's Avatar
mrr23
St. Jude Donor '15
video on installing the rockers
Old Jul 13, 2014 | 03:01 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
well the crap ebay tool is just that. good thing i have contacts at vinci high performance and picked up a real dual spring tool to get this done today. doesn't center well. have to pry it around to get the locks in. almost doesn't compress enough to do that. wasn't whittled away enough in the retainer area so it's sits lope sided on it.
Old Jul 13, 2014 | 03:02 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
here's what the vinci spring tool looks like on the spring retainers. self centers on the head and retainers. more than enough thread to compress the spring to get the keepers out.
Old Jul 13, 2014 | 03:06 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
old springs off
nice to see rust on the old springs
new springs on
yella terra rockers on
driver's valve cover clean and on
Old Jul 13, 2014 | 03:27 PM
RonSSNova's Avatar
RonSSNova
Those are the older style YT rockers. Will be fine I'm sure because you are using light stock springs.
What led you to do this upgrade vs simply adding trunion kit to the stock rockers? And why not go to a little better spring?
Just curious
Ron
Old Jul 13, 2014 | 07:03 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
Just curious
Ron
Rockers $100.00 used from forum member.
Springs $50.00 used forum vendor.
Here's a write up about stock rockers and how they really don't start at 1.7 off the seat and eventually get to 1.70 almost at the max lift.
http://vincihighperformance.com/LS1%...HTML#quicklift
Not to mention aftermarket heads come with bronze valve guides and stock rockers will ruin them in no time. (Later upgrade)
If I ever change from stock cam I'll get better springs.
I did this now because of 111k on the clock and a slight miss. Good thing I did as you can see in the pics where #2 cylinder exhaust rocker twisted on the pedestal mount. won't ever have this happen again.
Old Jul 13, 2014 | 07:06 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
just for the record. no shims and no hitting the stock covers with baffles still in place.
another side note. the shims aren't there to correct lifter preload. they are used to correct valve tip placement. you correct lifter preload with different pushrod lengths. refer to the video to hear that explanation.
Old Jul 14, 2014 | 01:48 AM
RonSSNova's Avatar
RonSSNova
Interesting. Now I know who Roger Vinci is.
Odd failure on the one rocker.
Ron
To yella terra rocker install
Old Jul 14, 2014 | 10:05 AM
vettenuts's Avatar
vettenuts
Nice looking rockers
Old Jul 14, 2014 | 12:19 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
Look familiar?
Old Jul 14, 2014 | 04:17 PM
RonSSNova's Avatar
RonSSNova
Vintage Bob rockers. Like fine wine.
