headers or axle back
Old Jul 12, 2014 | 02:04 PM
Bpaschke's Avatar
Bpaschke
2023 C5 of the Year Finalist - Modified
Default headers or axle back
I am going to be doing a set of Longtubes and a corsa axle back, cant afford to do both at the same time tho. So which one should I do first?
Old Jul 12, 2014 | 02:10 PM
NukeC5's Avatar
NukeC5
Do the axle back because it doesn't need tuning. Then when you do the LT's have it all tuned together
Old Jul 12, 2014 | 02:33 PM
Bpaschke's Avatar
Bpaschke
That's kinda what I was thinking. Thanks
Old Jul 12, 2014 | 07:53 PM
Cybermind's Avatar
Cybermind
I tend to disagree. The axle back adds nothing as far as horsepower is concerned. The headers will definitely add horsepower and you will get a nicer (louder) exhaust tone regardless of which catback you have. You do not need to retune once you get the catback.
Old Jul 12, 2014 | 11:15 PM
White Out's Avatar
White Out
Headers, gain power and sound. A tune isn't necessary.
Old Jul 13, 2014 | 12:12 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I was going to sellect headers first BUT,,,,,,,,,,,,,,,,,,,,,,, After the OP stated that he "COULDNT AFFORD TO DO BOTH" ,, I had to drop to CAT BACK system. A CAT BACK System shouldnt change the cars tune.
REASON,,, YES you should do a tune when you do headers. Will the car run with out a tune after header installation?? YES it will BUT,,, you will most likely loose some fuel efficiency (fuel Mileage) and maybe have some mild driveability issues.
Do ALL the mods that you can at one time.. Headers, CAT Back, VARARAM, Ported TB LS6 or better intake manifold, 36 lb/hr injectors and then get your tune.
BC
Old Jul 13, 2014 | 08:00 AM
Blow Torch's Avatar
Blow Torch
Yep
Old Jul 13, 2014 | 10:32 AM
NukeC5's Avatar
NukeC5
I prefer my car to be running at its best at all times . Would never do a set of LT's and run around leaning my engine out, or fouling up the valves, spark plugs, and or cats, and or sensors, with richness. A tune certainly is needed for a (good) set of headers. And if you aren't going to take advantage of the full benefits, why do it?
If one, and only one was going to be done, ya, headers no doubt. If both will be done, sorry but you'd have to be a fool to put on the headers, tune it, then change the axle back again. Tune together because it does make a difference.
Old Jul 13, 2014 | 10:35 AM
Chicago1's Avatar
Chicago1
you want sound or power? Like others said headers first and you will get a little more sound. A tune isn't required but recommended for full benefits.
Old Jul 13, 2014 | 12:16 PM
10sec89's Avatar
10sec89
I took off a aftermarket cat back and put a base Corvette( non Ti ) cat back on, and with the long tube headers and off road x pipe it sounds great! NO drone, loud on acceleration and quiet at cruise. I noticed no power loss. I vote headers first!
Old Jul 13, 2014 | 08:35 PM
Bpaschke's Avatar
Bpaschke
The other question I had is, is there any reason I can't use a 01+ intake (such as a halltech) on my 00? From what I understand is that the maf sensor is a little smaller.
Old Jul 16, 2014 | 02:25 PM
Bpaschke's Avatar
Bpaschke
Well I just ordered LT's and a Blackwing from texas speed
Old Jul 16, 2014 | 02:28 PM
NukeC5's Avatar
NukeC5
Different air bridge and MAF. There are a lot of intakes made in both 97-00 and 01-04 options.
To headers or axle back
