p0030x2
Old Jul 13, 2014 | 10:40 PM
LMFD296's Avatar
LMFD296
Default p0030x2
Here is the story. 2002 c5 6spd. Xs power Lt's and exhuast. Haltech intake. (When installig the Lt's i had to replace the drivers a/f as the oem broke. I replaced it with a denso unit.)Got tuned by chuck cow literally right after i finished the install.Car ran great for 2 weeks(probably less than 150 miles) . Then the car threw a p0030. A/f bank 1 sensor 1. I change it out thinking maybe the new a/f was a bad unit. Clear the code run it for about 60 miles.( over the period of 2 weeks) light comes back on for same thing p0030 b1 s1. So now im a little dumbfounded. Is it possible the tune is lean and burning out that o2? Or maybe i need to use an oem unit? Or could it be another bad sensor( slim chance) any advice or ideas would be great.
Old Jul 14, 2014 | 07:34 AM
Cutlassmaster's Avatar
Cutlassmaster
Have you gotten back under the car to ensure that none of the wires are damaged? Have you checked the fuses?
Chris
Old Jul 14, 2014 | 11:08 AM
LMFD296's Avatar
LMFD296
All the wiring is fine. The last sensor looked fine as well. I haven't checked the fuses. I figured the light would immediately come back on if one was bad. I however will check today. What one do i i look at?
A little extra info. On the freeze frame both times the code has triggered at 2100 or so rpm. It say slow response. Maybe I need a gm sensor.....
To p0030x2
