Alignment after spindle swap?
Old Jul 14, 2014 | 09:04 PM
NukeC5's Avatar
NukeC5
Default Alignment after spindle swap?
I just installed my LG drag spindles on the rear. Obviously the geometry of the control arms changed because its a shorter piece. So I assume the alignment is off?
Old Jul 14, 2014 | 10:24 PM
lionelhutz's Avatar
lionelhutz
Yup, if you cranked the bolts up to reset the ride height then the alignment is off. If should be checked anyways just because you made such a big suspension change.
Old Jul 14, 2014 | 11:56 PM
NukeC5's Avatar
NukeC5
Well I didn't touch the ride height.. I run coilovers. But the upper control arm is what's pulled lower to connect to the shorter spindle. So it must have messes with it a little. I guess I'll go for an alignment.
Old Jul 15, 2014 | 12:20 AM
lionelhutz's Avatar
lionelhutz
Oops, you did the shorter spindles not the lowering spindles. Then yes, when you lowered the upper a-arm ball-joint position you pulled in the top of the tires and added camber.
Old Jul 15, 2014 | 01:15 PM
NukeC5's Avatar
NukeC5
Im doing the alignment now. Surprisingly it pushed the top of the wheels out. So it was positive by quite a bit.
Old Jul 15, 2014 | 01:18 PM
mrr23's Avatar
mrr23
St. Jude Donor '15
Unless the arms were perpendicular to the road to begin with, it would have went more positive camber. Most likely your car is lowered so the arm was pointed upward which results in more negative camber due to the arc the arm travels when moving up/down.
Old Jul 15, 2014 | 01:54 PM
NukeC5's Avatar
NukeC5
Yup, either way, it's taken care of now
To Alignment after spindle swap?
