Hard to get into reverse
Old Jul 25, 2002 | 11:13 AM
bigwave's Avatar
bigwave
Default Hard to get into reverse
I need some help on my MN6. I have 23K mile on her and just yesterday it got very difficult to get into reverse we are talking major effort here. I have the stock shifter but I did cut it down about 1.5" All the other gears seam OK and there is no clutch smell or slipping going on. The only thing that happened was when I cut the shaft down I really had to torque down on the **** to get it to line up right but that was 6 months ago and has been fine until yesterday. Please help if you can. I think I need to see the dealer but it would be nice to have some advance info before they tell me this is normal.
Thanks everyone in advance
Old Jul 25, 2002 | 11:30 AM
Andy@A&ACorvette's Avatar
Andy@A&ACorvette
Platinum Supporting Vendor
Default Re: Hard to get into reverse (bigwave)
Is it really hard to move sideways? If so , there is a lockout solonoid that is amlfunctioning. Mine did that , so I took it out and ground the end of it off and reinstalled it.
Old Jul 25, 2002 | 11:42 AM
bigwave's Avatar
bigwave
Default Re: Hard to get into reverse (Andy@AandACorvette)
I think you hit the nail on the head Andy. It is normal to move side to side in the forward gear gates but the second I try to hit the reverse lockout I have to get out of the car put my foot on it and force it in :jester Ok maybe not that bad but getting there. I assume this is a warranty issue and its great to have a little heads up info before I show up there.
Thanks Again
Old Jul 25, 2002 | 12:34 PM
ncvetteman's Avatar
ncvetteman
Its normal for these brands of Transmissions. My last Mustang GT did the same, my 2000 C5 does. You can put it in 1st and move forward a couple inches then shift to R, or you can let out on the clutch a little and it will go right into R. Some just shift to reverse before they cut off their car so its already there.
Old Aug 7, 2002 | 03:32 PM
bigwave's Avatar
bigwave
Default Re: Hard to get into reverse (ncvetteman)
Hey Andy, I set an appointment to see the dealer for my reverse look out solenoid but I have a question for you. Do they have to pull the shift **** of for this or is this done from under the car. I have the factory **** on a cut down shaft with no retaining clip. I have this thing on so tight it will three guys to get it loose. Just would like to know before going.
David
To Hard to get into reverse
