Dash light problem?
Old Jul 25, 2002 | 02:15 PM
RMVette's Avatar
RMVette
Default Dash light problem?
I've noticed while I'm driving my '98 that the "MPH" on the speedometer glows from low intensity to brighter (headlights off). It seems to change occasionally even when the outside lighting is bright. Anyone else seen this, and is there a fix for it? Thanks all in advance!
Robert
'70 350/350 4-speed rally red coupe
'98 6-speed silver coupe
Old Jul 25, 2002 | 03:57 PM
bgood's Avatar
bgood
Cruise-In IV Veteran
St. Jude Contributor
Default Re: Dash light problem? (RMVette)
Interesting... I noticed my 98 C5 doing the exact same thing just a few days ago. The MPH light on the dash will vary its brightness intermittently. Head lights and fog lights are off. Anyone one have any ideas? :crazy:
Old Jul 26, 2002 | 08:39 AM
THRAP 42's Avatar
THRAP 42
RMVette,
It's normal ops. The sensor is dimming the MPH based on the amount of light that is being seen inside the cockpit. A lot of light = dim, low light = bright.
Nothing to worry about. Kind of like the twilight sentinel. It's not broke so don't know if there is a "fix".
later,
Old Jul 26, 2002 | 08:46 AM
jtk30093's Avatar
jtk30093
Default Re: Dash light problem? (THRAP 42)
The sensor that measures cockpit light is right above the FUEL button. The next time your in your vette move your hand over this sensor and you will see the "MPH" dim and brighten as you move your hand across the sensor.
This is completely NORMAL.
Old Jul 26, 2002 | 08:56 AM
RMVette's Avatar
RMVette
It's strange that it does it without the inside light level changing. I could be sitting in the driveway and it happens. Where's the sensor located that senses light level inside the drivers compartment?
Robert
'70 350/350 4-speed coupe
'98 6-speed coupe
Old Jul 26, 2002 | 06:05 PM
Redvette_22's Avatar
Redvette_22
Default Re: Dash light problem? (jtk30093)
That would be interesting if this is the fact. My dealer has been looking for the same problem in my car since Sept 98, and still has no idea.
To Dash light problem?
