Correct. But there is always a driver. It will be a minor change that won't affect the overall tire wear.
Thanks for the answer.
So if I understand correctly, anytime you do a wheel alignment you should be sitting in the car or put the equivalent of your weight in the car?
Is this in general for every car or just sports car like ours?
Some BMW (& benz?) have a preload weight spec for alignments;
X amount of lbs and no request for the driver. Some are front floorboard and trunk... Only in Germany
Specs are designed with no one in the car. People that race want everything to be the same with them in the car. Also there are times when people are like the OP that are a little larger than the average person. This can cause some pulling issues.
Do you have to be in the car or simulate it? No. But doesn't hurt. I understand what happens when someone sits in the car, so I align with that in mind.
Here is a BMW spec. Mercedes require a special tie rod presser bar to put between the front tires.
