Air Bridge
I just switched from the stock air bridge to the WCC high flow bridge. The coupler for the stock unit has a 4-3/4" outlet and a 4" inlet. The new air bridge is 4" for both inlet and outlet.
C5 Air Intake Info
"In designing the C5 GM engineering did a ton of testing and from that wrote adaptive strategy that made assumptions as to air and fuel flow under different engine conditions.
Changing those airflow parts, especially larger ones, reduce the velocity and the A.S still functions as if the stock parts were being used and how it was programmed and does not change even with tuning.
Most cases when the gas pedal is lifted and goes into “decel” with the larger airflow parts confuses the PCM and is adding or removing fuel when it really did not have to.
A cylinder can only hold so much volume and that is with a mix of air and fuel which is only in grams, yet the intake manifold holds quarts of air and the intake runners can only allow as much air mass as the runner size increasing MAF, air bridge or TB cannot make the runners of cylinders flow or pack in more volume then their size is.
If you monitor your engine with a PCM scanner you will be lucky to see a NA engine consume more then 600 CFM of air when a stock 75 mm MAF or TB is 750 CFM so they are never the delimiting factor of not feeding enough air to the engine.
Slowing the airflow down by using a larger air path to intake can, in fact cause ill low engine load performance. A pretty air bridge does not win races or give proper balance of the correct amount of air and fuel needed in all engine loads or conditions.
Larger airflow requires what GM did with the C6 and that is a new faster PCM with A.S software to make use of the airflow to help response times and not to make more HP."
C5 Air Intake Info
I'm sure that the aftermarket CAI manufacturers had nothing to do with spreading this myth.....
