2003 Needs New transmission?
Also just had rear hub replaced the day before. Technician says coincidence would have nothing to do with this.
88,000 km's (55,000 miles)
What do you guys think of all this? Seem reasonable? I'm no mechanic.
Do yoi have any PCM Diagnostic Trouble Codes (DTCs)???
READ AND POST the DTCs using the DIC:
READING YOUR Engine Diagnostic Codes
The Diagnostic Display Mode is entered with the following procedure:
1) Turn on the ignition but don't start the engine. NOTE! You can read the DTCs with the engine running and or driving down the road but it can distract you. BE careful! Some DTCs clear themselves when you turn the ignition OFF!
2) Press the RESET button to turn off any warning messages. (i.e. door open, trunk open ect)
3) Press and hold OPTIONS
4) While holding OPTIONS, press FUEL four times within a 10-second period.
Initially, on-board diagnostics go into an Automatic Mode which shows diagnostic codes in a pre-set sequence: PCM - TCS - RTD - BCM - IPC - RADIO - HVAC - LDCM - RDCM - SCM - RFA. All codes will be displayed for each. ( i.e. PCM = 4 codes) If none are present in a given module, you will see No More Codes on the display.
There are two kinds of diagnostic codes, Current and History designated with a letter suffix, “C” or “H”. A current C code indicates a malfunction is present and active in the module displaying data. A history code indicates a problem existed sometime in the last 40 or 50 ignition cycles. When not accompanied by a current code of the same number, it's potential evidence of a previous problem, now resolved, that was not removed by clearing the codes.
More likely it's an indication of an intermittent malfunction.
Intermittent codes are the most challenging of the diagnostics. An intermittent code may have happened once, may have happened more than once but is inconsistent or may be happening on a regular basis but not at the time the codes are displayed. History codes can also be caused by a current malfunction in a system that is not operating at the time codes are displayed. An example is the rear window defogger which doesn't operate until the Body Control Module detects engine rpm. For history codes set by a module that does not operate with the key on and engine off, a special diagnostic tool called a Scan Tester is necessary to properly diagnose the malfunction.
Once the system has displayed all modules, it goes into the manual mode which allows selection of each module using combinations of Driver Information Center buttons. Manual mode can also be entered during the automatic sequence by pressing any button except English/Metric (E/M). Once the display shows Manual Diagnostics, select a module by pressing the OPTIONS button to go forward or the TRIP button to go back. Once a module is selected, a code is displayed, and if more than one are present; press GAGES to go forward or FUEL to go back.
To exit the diagnostic mode at any time, press E/M. If you want to erase codes in a given module, press and hold the RESET button To reset the codes once in manual mode, press and hold RESET until it displays NO CODES Press OPTIONS to go to the next module. Repeat the steps until you have reset the codes in all the computer modules.
NOTE!! Only reset the codes IF you want to - it is NOT necessary to do this. Clearing a code does not repair a problem. You are simply erasing the evidence of it in the module's memory. If you clear the code/s, and extinguish the Check Engine Light, your emissions status ready will NOT allow you to pass an emissions test until you have completed the required driving cycles.
Once you have the codes, the next question is: What to do with the information?
First, consult the factory service manual. Any serious C5 Do-It-Yourself owner should invest in the Corvette Service Manual of the appropriate model year. The Service Manual is really a requirement if you want to understand and work on your C5. You can GOOGLE the DTC and also find information on it.
Here is very good site that explains the DTCs:
http://www.corvette-web-central.com/C5DTCcode.html
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix!!
Thanks for your reply. I do know how to check the codes and have a reference sheet and there are no codes related to the transmission and no current codes. My understanding from reading other psots on transmission issues on the C5 is there is no dipstick for the transmission on a C5 so I did not check the fluid. I am assuming (perhaps wrongly) that the Technician would have considered the fluid levels. I think the only way to check is to drain it and measure what comes out? Is that right? I have only owned the car for a little over a year and have not changed the fluid. maybe I should have.
DONE!
IF,,,,,,,,,,,,,,,,, You remove the plug with the engine off, you will loose a whole bunch of ATF immediately!
Bill
DONE!
Bill
Ive seen "STEALERSHIPS replacee an ENTIRE ENGINE due to a clogged CAT and charge the qwner $6500.
It could very well be damaged but,, you may also find an independant shop to do the work for less.
I do not know if theres a way ELECTRONICALLY to check the fluid level. At leaset the service manual doesnt reference any.
Bill
http://www.rpmtransmissions.com/
A few years ago I checked my trans fluid level. It was at operating temperature. It was FULL and the trans still slipped. I checked again and I waited until the fluid temp dropped to the factory specified temp. I was 22 oz. LOW!! refilled the trans, no more slipping.
Thanks again for all your advice.
