headlight
Old Aug 6, 2014 | 06:40 PM
wagner262's Avatar
wagner262
Default headlight
Headlights go up when the car starts and down when the car is turned off no matter the position of the switch control. When just accessory is on and no engine the headlights function just as they should with the switch control. Any idea what my problem is?
Old Aug 6, 2014 | 08:07 PM
Dave-A's Avatar
Dave-A
St. Jude Donor '14
Twilight is turned on with no delay time.
Old Aug 6, 2014 | 08:19 PM
wagner262's Avatar
wagner262
what does that mean and how do I get it off?
Old Aug 6, 2014 | 08:24 PM
65GGvert's Avatar
65GGvert
Go into the DIC options and select "twilight sentinel" and disable it. You don't have the sensor on the dash covered or maybe it has fallen down into the dash? It could also be bad. Either way, if you disable twilight sentinel, you should be in normal headlight switch operation. There's a page in the operators manual if you need instructions.
Old Aug 6, 2014 | 08:26 PM
wagner262's Avatar
wagner262
oh I can find that I guess Ive never really messed with the dash options before haha thanks guys Ill give it ago and let you know
Old Aug 6, 2014 | 08:28 PM
wagner262's Avatar
wagner262
guess it worked thanks guys! Learned something new today
Old Aug 6, 2014 | 08:32 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
To headlight
