Power Window Noise
Old Aug 8, 2014 | 09:19 PM
OLORN76djs's Avatar
OLORN76djs
2nd Gear
Default Power Window Noise
Drivers side window has scratch noise when opening or closing
Old Aug 8, 2014 | 09:23 PM
OLORN76djs's Avatar
OLORN76djs
2nd Gear
Default C5 corvette power window squeaks when opened or closed
Rubbing noise seems to be in the rear track
Old Aug 9, 2014 | 01:02 AM
Boss75's Avatar
Boss75
Usually that's a sign that the cables on the regulator are failing. I had that same noise in mine and changed the motor/regulator and I could see where the cable was coming undone in the old one.
Old Aug 9, 2014 | 08:13 AM
dadaroo's Avatar
dadaroo
Here is a good link to remove the door panel.
http://www.vetteessentials.com/instr...or_handle.html
To Power Window Noise
