Code problems
Old Aug 12, 2014 | 10:46 PM
ZubikC5's Avatar
ZubikC5
Default Code problems
Please help
1999 C5 corvette modded heads cam header x-pipe etc
Here are my codes and my check engine light is on. I also get service abs and traction control. what's wrong?
10-PCM - Powertrain Control Module
P0113 Intake Air Temp (IAT) Sensor Circuit High Voltage Plus P1111 not listed both HC
28-TCS - Traction Control System
C1225 RF Excessive Wheel Speed Variation H
A0-LDCM - Left Door Control Module
U1064 Loss of Communications with BCM H
B0-RFA - Remote Function Actuation
U1016 Loss of Communication with PCM H
U1064 Loss of Communication with BCM H
U1096 Loss of Communication with IPC H
Old Aug 13, 2014 | 05:50 AM
ZubikC5's Avatar
ZubikC5
Default bump to the top please help
Bump to the top please help
Originally Posted by ZubikC5
Please help
Old Aug 13, 2014 | 11:51 AM
dadaroo's Avatar
dadaroo
Looks like P0113 is setting off your CEL. I would clear everything and see what comes back. I would assume that one code will and not the others.
Not at home with my FSM but will be able to help later.
Old Aug 14, 2014 | 12:47 PM
jb35007's Avatar
jb35007
check your ground next to the alt on drivers side rail.....
also double check your maf connection as your iat is also included in the maf sensor..
wheel spin sounds like it would be a vehicle speed sensor???
Old Aug 14, 2014 | 12:49 PM
jb35007's Avatar
jb35007
H means it happend in history meaning it isn't going on right now...
only concern yourself with "HC"
that means "history & current"
Old Sep 3, 2017 | 06:44 PM
99torchredlb's Avatar
99torchredlb
Please help
Did you ever fix the problem ....this is exactly what my codes are reading
Old Sep 3, 2017 | 09:20 PM
99bluvet's Avatar
99bluvet
C1225 is for left front Excessive Wheel Speed Variation. Some of the references have is listed incorrectly.
To Code problems
