So, just had the trans rebuilt at rpm and it shifts smooth. Took the rear all apart and cleaned the crossmember and all. Just put it back together and I have a very loud clunk in the rear. I checked all the bolts and everything. Tight. Halfshafts are greased, torqued and all. It's speed dependant, so the faster I go the louder and more aggressive the clunk. The diff was perfect before I pulled the trans so it can't be that. Amsoil fluid in the rear and trans. Could I have gotten water in a wheel bearing? The noise is Def from the rear transaxle area. Ideas?
LOL
I do it all the time. Chock the front wheels, jack the back, rest on stands and let her run in 2nd gear for a few seconds while you listen for the noise.
My camaro always clunked in the rear till i got an impact wrench to pound down the bolts between the torque arm and the diff. Just wasn't possible to get it tight enough to not clunk but couldn't feel that it wasn't tight. Only did it on initial accel load and then initial decel load. Once i started just driving it home with the impact i no longer had issues with it.
With having everything out recently. I would put a wrench on every bolt i had out to check it was properly torqued before i dug too deep.
Did you change anything at the same time, with your transmission? If nothing changed, it could be the new trans.
I guess it's possible, but hard to think a new level 4 rpm trans would be bad enough to have that severe of a clunk. I don't even know what would make that sound. Plus it still does it in neutral coasting so no trans load. I just need to do what bill said and get it in the air and let it run.
Also, took it all apart and nailed all the bolts down. Nothing is loose. Plus you could time the rotation of the earth to the noise...it's not a loose bolt. It's something spinning.
it sounds to me like the half shaft may not be fully seated on the differential output shaft. sometimes it takes a good shove to get those things to go past the snap ring all the way.
Man do I feel stupid....turned out to be the brake cable grabbing a wheel weight each rotation. Lol. Can't believe the noise was made from that. Haha. Deeeerrr
I was going to suggest this! Same thing happened to me.
