Pre-detonation noise
Old Aug 19, 2014 | 12:42 PM
Oh 2 Fun's Avatar
Oh 2 Fun
St. Jude Donor '09, '13, '15
Default Pre-detonation noise
My C5 is stock and driven regularly, has 109K on the clock but still runs and drives very well.
If I sneak up on the power curve, it does fine. But when I put the fuel to it for max acceleration, I get some pre-ignition noise (rattling sound)around four or five K rpm.
Is this because of carbon deposits or will a good tune help? It's got new plugs and wires and I run premium fuel only.
CAI and aftermarket cat-backs as well.
The noise just makes me cringe....
Old Aug 19, 2014 | 02:09 PM
dadaroo's Avatar
dadaroo
DIC codes?
Old Aug 19, 2014 | 03:16 PM
RonSSNova's Avatar
RonSSNova
You could have a dead knock sensor. I'm not sure if that illuminates the check engine light.
That said, the knock sensors also have to "hear" the knock before reducing timing to fix it. This might be what you are hearing as well.
A good tune up if it's been awhile is always a good idea.
BTW Greg, bring it by. We can datalog it!
Old Aug 19, 2014 | 03:41 PM
3sACROWD's Avatar
3sACROWD
How new are the CAI and exhaust? If new, the car may not have adjusted to the set-up yet or the tune in not correct. Check for codes as others suggested. Is the acceleration weak or strong?
Could also be dirty injectors, dirty MAF, weak fuel pump, or clogged fuel filter. Not sure what year your Vette is. If pre-mid 2003, the fuel filter is a quick and easy change. Buy a Wix brand filter not the AC Delco. (Much cheaper and exact same filter) I'm guessing it is the original and wouldn't hurt to change anyway and an often overlooked maintenance item.
Old Aug 19, 2014 | 04:38 PM
Oh 2 Fun's Avatar
Oh 2 Fun
Hmm....interesting....and some possibilities I did not suspect.
It's a 2002. The CAI was on it six years ago and the exhaust has been on for about four years.
No codes. No check engine.
Fuel filter changed about a thousand miles ago. Plugs and wires about the same.
I can accelerate plenty fast without burying my right foot, but when I do bury it, I get this ping/rattle in a certain range rpm.
Could just be crappy fuel too. I usually fill at Costco or Safeway...sometimes Chevron.
Thanks for some ideas folks....appreciate it.
HEY....RON!!....I just realized that was you. Hope you are doing well. I'm still in Beaverton, Rainier on the weekends. What's "data log"? Is that a performance data collection process?
Old Aug 19, 2014 | 06:55 PM
RonSSNova's Avatar
RonSSNova
Hey Greg.
Yes, we can log and watch real time pretty much any engine function.
Including the knock sensors.
Ron
Old Aug 19, 2014 | 08:00 PM
Oh 2 Fun's Avatar
Oh 2 Fun
Originally Posted by RonSSNova
Hey Greg.
Ron
If you have the equipment, sign me up.
I'm usually in Beaverton during the weekdays.
PM me sometime.
Old Aug 19, 2014 | 10:13 PM
RonSSNova's Avatar
RonSSNova
Already did Greg!
Old Aug 19, 2014 | 10:41 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
Hey Greg.
Ron
I'm confident Ron will find the problem?
Old Aug 19, 2014 | 10:44 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
Don't forget to let us know.
Old Aug 19, 2014 | 11:03 PM
Oh 2 Fun's Avatar
Oh 2 Fun
Already did Greg!
T'aint showin' up in me box.....
To Pre-detonation noise
