Weiand LS1 polished intake
The aluminum manifold suffers from heat stroke (woops,, I meant to say soak)
more than the composite nylon manifold.Your need for more power is NOT going to come from a manifold only swap.
You need a combination of mods to make a worth while gain.. When you change ANYTHING between the MAF and the O2 sensors, you change the engine efficiency and need to have it retuned to take full advantage of the improvements.
A professional tune is $400-$500.
I don't see why a Weiand LS1 manifold wouldn't fit under a stock hood. Its not any bigger than a stock intake
If you want a pretty intake, hell,, GET IT.
Bill
Bill
After seeing the prices of these LS6 intakes I am pretty sure I'll just buy a blower first then change the manifold over at a later date if I need to.
