HVAC heater door stuck opened?
Old Aug 21, 2014 | 11:10 PM
scottsphoto2's Avatar
scottsphoto2
Default HVAC heater door stuck opened?
Zzup guy's?
The heat index hit like 110 deg., yesterday here in N.W., FL., and of course my a/c quit in my 97 c5!
I had the complete system replaced 01/2011(that is, everything under the hood, not inside the car.)
It is blowing hot on the driver-side and next to hot on the pass-side!
In the past, once I used the old pull #18 & #27 fuses, to get it straightened out, when I had hot on the d-s and cold on the p-s, but this time that's not the case, It's pretty much hot to warm on all the vents, but like I said, the p-s is a little cooler than the d-s.
I have already checked the refrigerant level. It was at the low end of the ok range, so I added enough to get it up to the top of that range.
(like about @ 50)
While I was adding it, the temp inside was nice and cold, but the next day, hot again!
got current code b0361
So after telling all of this to my vette mechanic today, he said it sounds like a heater door is stuck in the open position. He said it may be something he could re-program or re-calibrate? If not he may have to go in and replace it.
Well, here's my question!
I would really love to fix this myself, instead of putting even more $$$$ into this car!
#1)- what does the 361 code left-actuator, "feedback short to ground mean?"
#2)-was he referring to pulling those fuses 18 & 27 when he said re-calibrate it? or what? (because I have already done that, if that was what he was referring to?)
#4)- since the problem is on the d-s, is it something an amateur could pull off?
#5)- How or where might I find out what parts I would need to do the job my self?
#6)- In other words, any info at all will be greatly appreciated, so that maybe, just maybe, this "want-a-be mech.", can pull this off himself, w/o having to go visit Leo the Vette man! (I should already own stock in his company! lol
Anyway, Seems like every time I get close to that double-din install, something else happens!$$$>>>>
>>>>"She's a real head turner, but HIGH maintenance!
Did that sound familiar to anyone out there that has ever been Married? lol:
So please help as soon as possible cause its down right HOT down here! (drove home on the interstate doing 85 mph, with my head stuck out the window, yesterday!)
Thanks for reading!
Chris
Old Aug 21, 2014 | 11:35 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Originally Posted by scottsphoto2
Zzup guy's?
(like about @ 50)
#1)-So first of all, was he referring to pulling those fuses 18 & 27 when he said re-calibrate it? or what? (because I have already done that, if that was what he was referring to?)
#2)-Which side will be the hardest to get to?
#3)- if the problem is on the d-s, is it something an amateur could pull off?
#4)- How or where might I find out what parts I would need to do the job my self?
#5)- In other words, any info at all will be greatly appreciated, so that maybe, just maybe, this "want-a-be mech.", can pull this off himself, w/o having to go visit Leo the Vette man! (I should already own stock in his company! lol
#6)- Does anyone know of another possibility of what could be causing the problem?
Thanks for reading!
Chris
If it is not a coolant issue then do a search here for ac actuator blend door replacement.
it is a pain to do you basically take apart the entire dash and console.
Old Aug 21, 2014 | 11:41 PM
BigGun's Avatar
BigGun
Geez man.....use the dic and pull the codes. They will tell if you have an actuator problem and even which side.
Old Aug 22, 2014 | 12:35 AM
scottsphoto2
BS!
Done checked the codes, and didn't want help from a SA anyway!
Old Aug 22, 2014 | 12:44 AM
scottsphoto2
Thanks dude!
0361 says the left actuator feedback short to ground.
What does that mean?
Old Aug 22, 2014 | 08:27 AM
92GA's Avatar
92GA
Oldtimer
Thanks dude!
I just had to replace one of mine. You'll have to find the dash removal instructions or just dive in. It's time consuming, but not hard. I'd replace them both if I would have found these before I did the job.
http://www.ebay.com/itm/Dorman-604-106-Temperature-HVAC-Air-Door-Actuator-Motor-/271564864691?pt=Motors_Car_Truck_Parts_Accessories&hash=item3f3a86fcb3&vxp=mtr
I bought mine locally and paid about $ 150.00 tax included, but had I found these I would have ordered them and replaced them both.
Old Aug 22, 2014 | 09:00 AM
Smoken1's Avatar
Smoken1
Here is what you are trying to get to--Pic's from Bill Curlee
Dash removal link-- http://tech.corvettecentral.com/2013...-dash-removal/
Old Aug 23, 2014 | 12:05 AM
BigGun's Avatar
BigGun
[/QUOTE]Geez man.....use the dic and pull the codes. They will tell if you have an actuator problem and even which side.
[QUOTE=scottsphoto2;1587653081]BS!
Easy dude. What BS? The codes told you you have a problem with the left side actuator. It will need to be replaced. The Dorman is a good replacement at about half the cost. Some say it can be removed from the bottom but seems most just remove the dash as I did.
Old Aug 23, 2014 | 12:40 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
IF,,,,,,,,,,,,,,, You have HVAC DTCs for ACTUATORS,, most likely the actuator is bad. The DRIVE gear for the output shaft can crack and is no longer attached to the output shaft.
You can:
Replace it with a new one
OR
Take it apart and reglue the gear to the shaft .
SOMETIMES,,,,,,,,,,,,, You can turn the HVAC OFF and enter the DIC and clear the DTCs and turn the HVAC off back on and the DTCs will clear and it will work normaly. Ive had to do this procedure several times to clear it.
If that doesnt work,, you will need to remove the actuator and replce or repair it.
BC
Old Aug 25, 2014 | 12:05 AM
scottsphoto2
BS!
Yeah, well next time you can leave the "geezzz" part off.
I wouldn't be on here asking questions, if I already knew the answers.
I guess I was hoping to find out what was wrong with the actuator, when the code said, "short to ground", I thought maybe it was a grounding problem. I didn't know for sure if I had to replace it. heck, I didn't even know what an actuator was till, I ask?
But anyway,thanks for the help, sorry bout the "BS" comment.
Old Aug 25, 2014 | 12:22 AM
scottsphoto2
You can:
OR
BC
Now that was some great info!
Do I need to have the car running, with the ac off, while I try that?
Or just have the ignition turned on, w/o the engine running?
Thanks so much for your time!
Old Aug 25, 2014 | 12:42 AM
skyvetted's Avatar
skyvetted
I actually JUST did this job yesterday. I recommend following the write ups that some of the experts here have written up for removing a few of the dash panels.
I used this one as a guide http://vette.tnreeds.com/actuator/actuator.htm
If you are agile/a contortionist then you can access the driver side actuator without having to remove the top portion of the dash board. I had to climb in and out several times in that position for various sockets. It's very time consuming, especially if you go slow and methodically. I think I spent 5 hours disassembling it, playing with it and reassembling it while cleaning up the panels as well.
Unfortunately for me, my actuator worked just fine but I needed to rule it out. I did learned a lot in the process.
My issue was a low refrigerant charge.
Old Aug 25, 2014 | 01:05 AM
scottsphoto2
thanks to ya, SMOKIN1,
for helping me get the job done.
Wish me luck!
About to order them, and try this.
Old Aug 25, 2014 | 03:48 AM
scottsphoto2
THANKS!
I just went thru that article, and I am about to try this before I buy a new one!
Wish me luck!
Old Aug 25, 2014 | 08:07 AM
scottsphoto2
Bill,
How many screws are holding on these actuators?
Any tips on making it easier to get them off?
Thanks,
Chris
Old Aug 26, 2014 | 07:19 PM
yankeevetteconvert's Avatar
yankeevetteconvert
Dorman 604 106 Temperature HVAC Air Door Actuator Motor | eBay
I clicked on the link and it said the actuator would not work on a C5.
I need one. Anybody got a link to one that will fit . 2002 C5 Dual control drivers side actuator.
Old Aug 26, 2014 | 09:35 PM
dmarkshark's Avatar
dmarkshark
no easy way, 3 screws. But, if the system was rebuilt, and it was low? Hum, I would be checking for leaks. Sometimes low Freon causes all kinds of strange issues that relate to the actuators not working correctly. I had the HVAC code 361, put in a new drivers side actuator, and it kept giving me the same code for the actuator, when in reality it was a Freon issue. For what its worth. PS, you need to find a new mechanic, really!
To HVAC heater door stuck opened?
Old Aug 26, 2014 | 10:36 PM
skyvetted's Avatar
skyvetted
I think, pulling the entire dash and removing the center metal framing holding the Radio and HVAC controller makes this job the easiest it can possibly get, lol.
Getting the BOSE box out of place is a MUST. It's held in by two screws. Pulling the driver seat would help loads too in retrospect. Just be sure and organize your screws in a way that you will not forget them. I also removed the ignition switch assembly and that helped quite a lot as well. That is held in place by three screws.
I'm definitely no Bill but this is all I recently learned and I sincerely hope it helps.
Old Aug 26, 2014 | 11:03 PM
92GA's Avatar
92GA
Oldtimer
That's the same part number that's on the box in my garage. I just put it in my 99 right side and it works great. If your car has the standard controller it's not the right one, but if you have the climate control it is the right one.
Here's the part number of the one I installed in my car 604-106. Bought at O'Reillys, check the number there.
http://www.oreillyauto.com/site/c/de...4160&ppt=C0331
Old Aug 26, 2014 | 11:11 PM
92GA's Avatar
92GA
Oldtimer
Bill,
Thanks,
Chris
I just replaced the right one in my car, it had 2 screws holding it on. Don't know about the left side, it was working so didn't replace it.
