Driver side window doesn't work nor lock
Old Aug 24, 2014 | 04:54 PM
paloalto00's Avatar
paloalto00
Default Driver side window doesn't work nor lock
Out of the blue after my car wash yesterday, my driver side window stopped working. I turned the car off then back on and it worked...Now today it won't work again. The buttons for the passenger side door work, just not for the driver's side.
Any suggestions?
Old Aug 24, 2014 | 06:26 PM
Murder_C5's Avatar
Murder_C5
If the window won't work at all & fuses are good, this FREE fix could help you out:
http://forums.corvetteforum.com/c5-g...-easy-fix.html
It saved me.
Old Aug 24, 2014 | 10:55 PM
paloalto00's Avatar
paloalto00
Thanks for the help guys, I ended up fixing it by simply pressing on the wires between the door and the car :O
Old Aug 24, 2014 | 11:50 PM
paloalto00's Avatar
paloalto00
Originally Posted by 8VETTE7
That's not a fix.....The problem WILL be back until you pull the connectors out of the accordion tube and address the problem with the pins in the connectors between the car and door wiring harnesses.................
How do I get that bad boy off? I was at a car meet so I was in a bit of a rush to get my window down to take the top off
To Driver side window doesn't work nor lock
