MAF..... Good or Bad
Old Aug 25, 2014 | 05:59 AM
UZISOLO's Avatar
UZISOLO
Default MAF..... Good or Bad
What are the effects of a bad MAF? Will idle be rough, missing at speed?
Old Aug 25, 2014 | 11:50 AM
TastyBacon's Avatar
TastyBacon
A MAF can be "bad" and not throw codes. My car had a de-screened cheap plastic aftermarket MAF in it. Since I replaced it with a clean, screened factory MAF, the idle is smoother, it's smoother in transition on and off the throttle, and the exhaust crackles and pops less.
Old Aug 25, 2014 | 01:33 PM
Fed Up's Avatar
Fed Up
"My Dad's a TV Repairman"
When you start cold, the car is in closed-loop, fixed programming until it warms up. The MAF will start affecting the engine after this passes, generally after the idle drops to normal run mode. If the car starts running badly after this warm-up period, think MAF.
Also, if the car runs better after disconnecting the MAF, think MAF.
Pull your codes- This is kind of key here.
To MAF..... Good or Bad
