Battery tender Hookup
Old Aug 26, 2014 | 09:19 AM
ChuckWalters's Avatar
ChuckWalters
Default Battery tender Hookup
Is there any other way to permanently hook up a battery tender wire/whip to the battery so that I don't have to keep removing the battery den cover all the time? Most tenders come with the the clamp ends but also with the stake on ends to attach to the battery posts. That connector does not lend itself to attaching to a side post battery very well. Can the tender whip be attached to a negative ground and the positive connector in the fuse box under the hood? This is not a direct connect to the battery and I don't want to hurt anything and will it charge the battery sufficiently if attached this way? Any other suggestions?
Old Aug 26, 2014 | 09:53 AM
ChuckWalters
Originally Posted by 8VETTE7
Have you considered using the cigarette lighter to plug in your tender to charge the battery? Don't need any external connections to the battery. Also safe to do since the charge current is only 1.25Amp and the fuse to the lighter is 10 amp. Never need to open the hood.
http://www.batterymart.com/p-12-volt...FZKBfgodP5cABg
I made up my own long extension from parts available at Radio Shack pretty inexpensively. Tender is on a shelf on the wall with the long extension ready for me when I drive into the garage. Even works with the car cover on.
Not a bad idea! Do you run it out the window?
Old Aug 26, 2014 | 10:47 AM
RedSoxFan's Avatar
RedSoxFan
I have a permanent hook-up for my ctek, your battery tender could be hooked up the same way. See my write-up in this thread.
http://forums.corvetteforum.com/c5-g...post1577496941
Old Aug 26, 2014 | 10:57 AM
camburger's Avatar
camburger
Well 8VETTE7 that's a slick method, I am tired of always managing this task the usual way.
Does the ignition have to be a specific way verses just turning the motor off and pulling the key?
Bob
Old Aug 26, 2014 | 12:51 PM
LoneStarFRC's Avatar
LoneStarFRC
Change out the standard battery side post bolts to these. There are a number of different brands/sources etc. They are common in audio/stereo stores. Attach your ring terminal cable, then route your cable to any nearby convenient location where you have easy access:
http://www.knukonceptz.com/default/a...fault/GMBT.JPG
or these:
http://www.offroadhardware.com/image.../sidepost1.jpg
Then buy a plug-in style extension cord. I used a 25' extension (there are shorter ones too) from Schumacher, but there's a number of other brands out there as well.
$10 to $15 price range:
http://www.crfsonly.com/catalog/imag...on%20Cable.jpg
Leave the charger on the bench, nearby shelf, or even mount to the wall next to the car, pull the pigtail attached to the battery out and plug the extension into it. When your done charging, unplug the extension and tuck the battery pigtail down out of the way where you can reach it easily the next time.
HTH
Old Aug 26, 2014 | 04:17 PM
RedZMonte's Avatar
RedZMonte
OEM Battery tender from GM:
http://forums.corvetteforum.com/c6-c...rts-house.html
All over ebay:
http://www.ebay.com/sch/sis.html?_nk...d=300651284676
we had a few of those battery tenders at the Lexus dealer i worked for.... we had a butch of them that didnt work in a drawer (same box with a "Lexus" Name on the front). So im not a fan of them.
I would recommend one by a brand called "Schumacher" i have had a few that have always worked... even OLD ones that the housing was coming apart always worked!
Amazon.com: Schumacher XM1-5 1.5 Amp Fully Automatic Power Charger and Maintainer: Automotive Amazon.com: Schumacher XM1-5 1.5 Amp Fully Automatic Power Charger and Maintainer: Automotive
Amazon.com: Schumacher SE-1-12S-CA  Fully Automatic Onboard Battery Charger - 1.5 Amps: Automotive Amazon.com: Schumacher SE-1-12S-CA Fully Automatic Onboard Battery Charger - 1.5 Amps: Automotive
Amazon.com: Schumacher SC-300A Speedcharge 3 Amp Charger/Maintainer: Automotive Amazon.com: Schumacher SC-300A Speedcharge 3 Amp Charger/Maintainer: Automotive
To Battery tender Hookup
