Fuel sender problem? ***URGENT HELP***
Old Jul 28, 2002 | 06:04 PM
Stingray1967's Avatar
Stingray1967
Default Fuel sender problem? ***URGENT HELP***
I was cruizin' around today with a little over a 1/4 tank left, the dash went "BEEP", the gas gauge went to zero, and the check gages light came on. I went and filled up the tank and it's fine now.
Is this the infamous fuel sending problem? The reason I'm asking is that my cars comes out from underneath the 3/36 from Chevy on THURSDAY!!!!!
I'm going to be on the phone tomorrow making an appointment, unless you guys can tell me different. Thanks!
Old Jul 28, 2002 | 06:14 PM
JWSchmidt3's Avatar
JWSchmidt3
Default Re: Fuel sender problem? ***URGENT HELP*** (Stingray1967)
That's it, mine does it to. Mine does it after 30-40 minutes of highway driving. I just live with it until I have time to take it in. Though, one shop here in Dallas refused to fix it unless it was actually doing it when I brought the car in. :rolleyes: Oh well, my shop in Houston will fix it when I get around to it.
PS - In some instances, I have heard fixing the unit, doesn't actually fix it. Some people have stated that after a few months, it started doing it again. FYI. :cheers:
Old Jul 28, 2002 | 06:39 PM
Smoke-N-Shot's Avatar
Smoke-N-Shot
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In VI Veteran
That is the problem directly... In my case I had corosion additionally which could of affected the fuel pumps from running... Have it fixed ASAP IMHO... Good luck!
Old Jul 28, 2002 | 07:06 PM
lioninavette's Avatar
lioninavette
From: Ponderables, yes. My opinion, not totally. Preaching...I don't have a pulpit. Fact and generalizations about what I am reading on behalf of what you tell me...absolutely.
Happened to mine too...
Get it fixed as long as you have the time. I think as long as you report the problem while the car is under warranty the dealer should cover it under the warranty.
Old Jul 28, 2002 | 09:28 PM
Stingray1967
Default Re: Fuel sender problem? ***URGENT HELP*** (lioninavette)
Let's hope so! :eek:
Old Jul 28, 2002 | 10:06 PM
Stingray1967
[b]Does anyone know how much this would cost OUT of warranty????[b]
Old Jul 28, 2002 | 10:47 PM
jimman's Avatar
jimman
I just posted a thread where my new 2002 with 2500 miles did it yesterday and again today. With my 2000 I had it replaced twice under warranty and it failed the third time but I traded for this one and wa-la doing it again. GM wouldn't fix it out of warranty, I heard anywhere from 500 to 700.00 to fix.
Old Jul 28, 2002 | 11:00 PM
Stingray1967
Default Re: Fuel sender problem? ***URGENT HELP*** (jimman)
Jimman, just read your other thread. Thanks for the reply on the cost. :D
Old Jul 29, 2002 | 09:19 AM
Smoke-N-Shot
$700.00+ dollars :eek:
Nick
Old Jul 29, 2002 | 11:17 AM
Stingray1967
Well guys, I got the appointment at the dealer made. Wish me luck!
Old Jul 29, 2002 | 12:42 PM
CFIVEM3's Avatar
CFIVEM3
Default Re: Fuel sender problem? ***URGENT HELP*** (Smoke-N-Shot)
Nick
Hmmmm...That's near the quote from Ken to extend my warantee for two years. No probs yet, though.
:cheers:
Old Jul 29, 2002 | 01:10 PM
VERTVETTE's Avatar
VERTVETTE
Default Re: Fuel sender problem? ***URGENT HELP*** (JWSchmidt3)
They all do. I think it starts the first time you over fill the car. :yesnod:
Old Jul 29, 2002 | 04:22 PM
Sun Downer's Avatar
Sun Downer
If you are out of warranty you can fix this yourself for about $50. Do a thread search and you should find all the info there. I did mine myself and have had no problems.
Old Jul 29, 2002 | 04:30 PM
RHILL's Avatar
RHILL
Default Re: Fuel sender problem? ***URGENT HELP*** (Sun Downer)
What did you do to fix yours?
R
A
Y
Old Jul 29, 2002 | 04:40 PM
RHILL's Avatar
RHILL
Here ya go http://forums.corvetteforum.com/zerothread?id=204030
Old Jul 30, 2002 | 09:34 PM
Jerryk's Avatar
Jerryk
I used to have the fuel sending problem, been using Chevron gas now and after about 6 to 8 tanks the problem has not returned or maybe try fuel cleaner :yesnod:
Old Jul 31, 2002 | 01:14 AM
jimman's Avatar
jimman
Default Re: Fuel sender problem? ***URGENT HELP*** (Jerryk)
Sorry jerry, my 02 with less than 2500 miles with Chevron has gauge problem.
To Fuel sender problem? ***URGENT HELP***
Old Jul 31, 2002 | 05:54 PM
Sun Downer's Avatar
Sun Downer
Default Re: Fuel sender problem? ***URGENT HELP*** (RHILL)
I bought the kit from GM. I got the part number off the service bulliten that was posted on the forum. It was a new level sensor curcuit and float arm. That was for the drivers side the passenger side I don't know a lot about.
Old Jul 31, 2002 | 11:06 PM
Nekbyter's Avatar
Nekbyter
Beg them to do BOTH sides at once. I had my left one go bad and thats all they replaced the first time around. Three weeks later I was in the shop again to get the right side replaced as well. All this down time really sux. :mad
Old Aug 5, 2002 | 01:00 PM
dangrass's Avatar
dangrass
I'm having some trouble finding the specifics. Could you provide the part number for the kit? What was involved in doing the work?
thx...
Dan
