will this work / be dangerous ?
Old Aug 30, 2014 | 02:25 PM
c5frcisdope's Avatar
c5frcisdope
Default will this work / be dangerous ?
The person who had my car before me completely removed the evap purge solenoid and capped the line off that comes from the back of the car. I wanted to restore the system, but he also cut the plug for the sensor. I have a new plug, and I can tap into the ECU wires, but I was wondering if this would work first:
Can I take the evap purge line from the back of the car, stick a check valve on it, and just hook it to the intake? See any major issues with doing this? It would take about 5 minutes instead of 2 hours to do. They only issue I could see is if the solenoid also regulated the amount of vacuum on the tank.
Thanks for the thoughts,
Old Aug 30, 2014 | 04:45 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Hmmmm,, I dont think so. The tank doesnt operate under constant manifold vacuum The tank VENTS into the charcoal canister and the PCM (Power Train Control Module) tells the system to PURGE the canister under ideal conditions as not to screw up idle or WOT AFRs
Give that idea a rest. Not the best plan for your car. If it was that easy, GM would have built it that way.
Bill
