oil psi
Old Sep 1, 2014 | 01:45 PM
Chuck A's Avatar
Chuck A
St. Jude Donor '08-'09
Default oil psi
yes i looked and did not find the answer, here goes
what psi should i have while doing 75 mph in 5th gear, i use mobil 1 synthetic, and really baby the car , i never really looked at it before about the psi, and it shows 48-50 is that ok, i plan on keeping vert and need to know if i need to bring car in to be looked at, i appreciate your help
Old Sep 1, 2014 | 01:54 PM
GeorgeZNJ's Avatar
GeorgeZNJ
Hi Chuck, I'm not a mechanic but I see about the same. C5 Z06,cammed LS3 485ishrwhp
Old Sep 1, 2014 | 01:55 PM
Chuck A's Avatar
Chuck A
thanks but it looks as though your vette in a Z06 with more power and probably is normal to have higher psi, thanks though for your response
Old Sep 1, 2014 | 09:36 PM
Chuck A's Avatar
Chuck A
any answers?
Old Sep 1, 2014 | 09:45 PM
pickleseimer's Avatar
pickleseimer
St. Jude Donor '12 thru '24
My '01 vert shows 43 psi on DIC at highway cruise, 65 mph, 6th gear (about 1300 rpm as I recall) , Mobil 1, 200 degree oil temp.
Old Sep 1, 2014 | 10:27 PM
Chuck A's Avatar
Chuck A
so i guess 50 is ok?
Old Sep 1, 2014 | 10:54 PM
pickleseimer
50 seems quite good if oil temp is at normal operating temp. My service manul is at the shop so next time I'm out I'll look up the spec for minimum oil pressure on the LS1.
Some info is available in the owners manual:
"Oil pressure should be 20 to 80 psi (140 to 550 kPa).
In certain situations such as long, extended idles on hot
days, it could read as low as 6 psi (40 kPa) and still be
considered normal. It may vary with engine speed,
outside temperature and oil viscosity, but readings above
the shaded area show the normal operating range"
Old Sep 1, 2014 | 11:55 PM
Stroker87's Avatar
Stroker87
my 03 c5z is 43psi 6th gear around 1700 rpm's mobile 1HM
Old Sep 1, 2014 | 11:57 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You have NOTHING at all to be worried about! NORMAL.
What is your HOT IDLE oil pressure??
BC
Old Sep 2, 2014 | 06:55 AM
Chuck A's Avatar
Chuck A
BC
around 42
Old Sep 2, 2014 | 07:11 AM
martysauto's Avatar
martysauto
St. Jude Donor '14
It's fine! Enjoy your car.
Old Sep 2, 2014 | 07:19 AM
Chuck A's Avatar
Chuck A
ok thanks
Old Sep 2, 2014 | 02:16 PM
Chicago1's Avatar
Chicago1
Originally Posted by Chuck A
around 42
I wish mine was like that oil temps in the mid 200's and idle at that temps in ~18-25 just depends then 60 plus cold and driving
Old Mar 22, 2015 | 10:11 PM
BARsC5's Avatar
BARsC5
I notice that when I start the car first thing and begin driving, my pressure is kind of high I think, starting at 40-50 but right before shifting, it creeps up to 60-80. Once the engine is warm, it seems to hang steady around 40-45 at a cruising speed.
My real question, do I need to baby this until it gets up to temperature to keep from damaging it? Will it cause harm running it to say 3000 RPM and causing the pressure to rise?
Old Mar 24, 2015 | 12:08 PM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
Oil pressure is derived from the oil pump spinning, so the faster the engine turns, the higher the oil pressure. When the engine is cold, the OP is higher, because the oil is thicker, so to speak, hence the higher OP. Personally, I drive somewhat slowly, until the engine begins to warm up. Yes, you're going to see 2000-2500 in the lower gears, when starting out from a stop, and yes, that will cause the OP to rise, but as long as you're now beating the crap out of it, it shouldn't be an issue.
To oil psi
