And yet another "pull key - wait 10 sec" after LMC5 install thread
I installed my LMC5 about 10 days ago, no trouble, as I said before, it took longer to read the 4 page directions than to actually do it. This was done prophylacticaly as I had no trouble before and there must have been some mod (maybe the GM recall) made to my car previously because my steering wheel would not lock. Anyway, it functioned fine for about a week, then I started getting the message to "pull key, wait 10 sec." when I went to start it. I did the recommended easy fix, to remove fuse #23 and to disconnect the battery and let the computer reset, and this worked for a day or two. Then backing out of a space yesterday, the car shut off with the "service column lock" message. I pulled the key, was able to restart it, move about another 10 feet, then the message reappeared and the car shut off again. Needless to say i was f**king pissed. The third time, luckily for me, the message did not reappear and I could drive the 5 miles to get home. Talking to Richard at Compliance Parts, he told me that maybe 1 out of every 200 C5's have this problem with the BCM and to do the brown wire fix as outlined in the directions on the bottom of page 2. I did that this morning and have started the car a half dozen times and get no messages, so right now everything seems to be working OK. Time will tell if this is a satisfactory remedy. I really dislike having to fix a fix for something that wasn't broken to begin with, but, this was done prophylacticaly to prevent the dreaded fuel shutoff, and after having experienced that, I'm still glad I did this. When that message and the fuel shutoff happens, you are just dead, sitting there wherever the car is, and that's not really an appealing situation. I hope my little extra brown wire hookup solves the little glitch I had, but I think everyone with one of these cars should install that LMC5 module to prevent getting stuck, and it's usually where you don't want to be.
Then immediately contact the vendor again for his help.
THe brown wire fix seems to work for the "pull key.... message but if it should not in your case, contact Compliance immediately.
Basically you again disconnect the neg battery terminal, remove the upper larger pink connector from the BCM, pull out the lower dark green 3rd wire from the right (diagonally down to the left from the previous one you replaced with the LMC5 wire) and replace this one with the brown wire from the LMC5, then cut the brown short wire loop sticking out of the LMC5, cap all the wire ends with the caps provided, replace the BCM back in it's holder, reconnect the battery, and you are done. Hopefully forever.
Which reminds me....I forgot to mail the original back to Richard. Does anyone happen to have his mailing address or Web address handy? I'm on a different computer and don't have the links on this one. Thanks!
