LS1 vs LS6
Old Jul 29, 2002 | 02:14 PM
Tomstoy's Avatar
Tomstoy
Default LS1 vs LS6
I recently read that the 02 LS1 shares the same short block as the LS6. Can anyone confirm? And if so what parts are different from earlier LS1's.
Old Jul 29, 2002 | 02:18 PM
thefly's Avatar
thefly
Default Re: LS1 vs LS6 (TORCH COUPE)
that is true, beginning in late 2001 both the ls1 and ls6 share the same block. also for all 2001's they also share the same intake.
Old Jul 29, 2002 | 02:21 PM
kewlbrz's Avatar
kewlbrz
Cruise-In II Veteran
Cruise-In III Veteran
Actually the LS1 began using the LS6 shortblock in late 01 production (minus the LS6 cam of course).
This has also been confirmed by c4c5specialist who has disassembled the engines for warranty work and such and seen the bay to bay breathing etc on the late model 01 LS1's. Im not sure of the exact switchover date tho.
The primary difference before late 01, was the LS6 used the different block.
[Modified by kewlbrz, 12:22 PM 7/29/2002]
Old Jul 29, 2002 | 03:00 PM
Miles in Michigan's Avatar
Miles in Michigan
Default Re: LS1 vs LS6 (kewlbrz)
Well, the block wasn't responsible for the power increases.
The main thing to increase power is the LS6 heads (visually distinguished by 'D' shaped exhaust ports), and the cam with more lift and duration.
Old Jul 29, 2002 | 04:51 PM
kewlbrz's Avatar
kewlbrz
Default Re: LS1 vs LS6 (Miles in Michigan)
thanks for the clarification Miles. I was simply referring to the shortblock. Your right tho. The LS6 in essence is just a mild head and cam jobbed, LS1.
Old Jul 29, 2002 | 05:27 PM
CJS's Avatar
CJS
So if you already have the LS6 block on a late 2001, then what would it be better to go with: stage II LS1 heads or stage I LS6 heads? Assuming a .221/.558/114 cam and longtubes?
Old Jul 29, 2002 | 05:48 PM
kewlbrz's Avatar
kewlbrz
Default Re: LS1 vs LS6 (CJS)
For the money, and if on a stock displacement motor, you can get more out of LS1 heads. Mostly because the bare ls6 casting are a grand.
Old Jul 29, 2002 | 09:57 PM
alc2001's Avatar
alc2001
Anyone know how to tell what block my 2001 LS1 has? It was built 12/00.
Old Jul 30, 2002 | 01:20 AM
Duck916's Avatar
Duck916
Default Re: LS1 vs LS6 (alc2001)
I'm gonna have a go at describing the external difference between the LS1 and the LS6. Look at the extension of the block deck on the right (passenger) side just forward of the head (where older small block motors had the serial number stamped). You will see a rough indentation toward the center of the block and a flat machined section toward the side of the car. On the LS1 the machined section is flat and on the LS6 the machined section has a slight machined cutout. It's hard to explain, but if you look at this part of the block on an older (early '01 and prior) LS1 and a Z06 side by side, you can easily see the difference.
Old Jul 30, 2002 | 01:57 AM
kewlbrz's Avatar
kewlbrz
Default Re: LS1 vs LS6 (Duck916)
Duck, this is my 2001 LS1 passenger side where you describe. Seems to fit your description of LS6. My Build date by the way was May 25th 2001.
[Modified by kewlbrz, 11:39 PM 7/30/2002]
Old Jul 30, 2002 | 10:17 AM
Catfish III's Avatar
Catfish III
Yaaa! It looks like I have a LS6 block too. My car was built at the end of Jan 01/ Beginning of Feb.
Old Jul 31, 2002 | 12:42 AM
alc2001's Avatar
alc2001
Duck,
Thanks for the info. Looks like mine would also be an LS6 block. So all I need now is the heads, cam, exhaust, clutch, MAF, MN12, brakes, wheels, windshield, etc and I'll have a ZO6.
Old Jul 31, 2002 | 02:14 AM
TAL's Avatar
TAL
I think my 02 Camaro Z28 has the LS6 block, too.
Build date of April 2002.
Check it out:
What do you guys think?
[Modified by TAL, 1:27 PM 7/31/2002]
Old Jul 31, 2002 | 02:44 PM
01Pewter's Avatar
01Pewter
CI 2-3-4-5-6-7-8-9-10 Vet
CI-X Auto-X Champ (street tires)
Cruise-In IX AutoX Winner
Just checked the engine bay.
My Vert was assembled Feb 01.
It appears to have the LS6 block. :cool:
Old Jul 31, 2002 | 03:25 PM
MDT's Avatar
MDT
I just went to the garage and looked at my 01 Coupe...It has the flycut on the boss as shown in the picture. Build date was first week in Dec. 2000.
Does anyone have an 01 which has the flat boss on the block at the position shown it the pic? If so would you post your build date?
Mark
Old Jul 31, 2002 | 04:43 PM
Catfish III
What is the differences between the old LS1 block and the LS6 block?
Old Jul 31, 2002 | 05:06 PM
kewlbrz's Avatar
kewlbrz
Default Re: LS1 vs LS6 (Catfish III)
LS1 block did not have bay to bay breathing, and the casting in the LS6 does. Also the LS6 is traditional sand cast. the ls1 is semi permanent mold.
To LS1 vs LS6
Old Jul 31, 2002 | 08:54 PM
MDT's Avatar
MDT
I ran across the link below which might be of interest to those following this thread.
http://www.idavette.net/hib/ls6/page3.htm
Mark
Old Aug 3, 2002 | 01:57 AM
Duck916's Avatar
Duck916
Duck,
Yup, you've got the LS-6 block. Not sure when they switched over, but you should see the difference if you look at a 2000 model.
Old Aug 3, 2002 | 06:35 PM
dangrass's Avatar
dangrass
This is interesting. So, it appears that most of the 2001 LS1's had LS6 blocks...but did they still have the LS1 breather setup or the new and improved LS6 version?
Dan
