I recently had 4 new TPMS sensors put on my 2000 C5. The rear sensors read perfect (30psi DIC reading and 30 psi actual); however, the two front tires erroneously read 39 psi DIC with 30 psi actual. My guess is those two TPMS sensors are defective as once all four are synced to read, there is no adjustment for individual sensors that are misreading. Am I missing anything?
Sounds like you hit the nail on the head. Defective sensors. You might want to try programming the backs as the front and the front as the backs just to prove a point. Just start your programming sequence at the back right tire and work clock wise instead of starting at the left front. See if the problem stays at the front of the car. If it does it is the module. Be sure to change them back again when you are done. What brand are they?
I'm having this same problem, off by exactly 9psi, with all four sensors at the same time. They were all four replaced in December of 2012. It makes me believe the problem is somewhere else rather than in the sensor. They program just fine with my strong magnet, just read the wrong pressure.
I've searched until I'm blue in the face for any type of instructions on how to adjust the pressure readout. I found nothing.
If anyone has any idea I'm open. I even though about buying another fob/tire module from ebay and trying to change it out. Anyone got one left over from updating thiers?
I assume you did "reprogram" the sensors to the car using a magnet after they are installed?
How to Reprogram sensor: This worked on a '04 C5 we reinstalled the original wheels onto (had aftermaket wheels on it) YOU WILL NEED A LARGE/STRONG MAGNET!
Try raising or lowering the pressure by about 10 lbs and see if it changes. If the car has been sitting you may need to take a short drive or use the magnet to "wake up" the sensors.
Sounds like you hit the nail on the head. Defective sensors. You might want to try programming the backs as the front and the front as the backs just to prove a point. Just start your programming sequence at the back right tire and work clock wise instead of starting at the left front. See if the problem moves to the front of the car. If it does it is the module. Be sure to change them back again when you are done. What brand are they?
I think you meant to say if the problem moves to the rear it is the module?
Jack up one wheel and depressurize the tire. Use a magnet to wake up the sensor and see if it reads ZERO. Repressurize to 30 and see if it reads correctly.
The pressure sensors read correctly at 0 (zero) pressure. The MAP sensor is reading correct when the key is switched on according to HPTuner's scan data.
Could there be another BARO sensor somewhere? Or, as has been found before, is the function of this system incorrect in the GM manual?
Any other ideas?
Next I'm going to program my spare set of tires and sensors but they weren't available today when working on it.
Any other ideas?
You need to create your own Thread instead of adding another issue to the OPs one. Makes it too hard to follow what is going on.
Ok, mini-mod, I'm on topic and you're not contributing to the thread. If someone does a search for the TPMS problem they'll find this information in one thread instead of spread out all over the forum with no end or solution to the problem, (which may end up the case anyway).
Resolved the TPMS problem. Of the four new sensors previously installed, the two installed in both front wheels were defective. Replaced both and now reading accurately in Driver Information Center. Contacted the Ebay merchant who sold me the original set of four (they were advertised as brand new GM OEM) and now waiting for a promised refund. Will update on whether vendor actually refunds.
Thanks for all the helpful posts
VR,
Ron
VR,
Ron
Just getting around to updating this thread. I did receive a refund of $100 a few days after requesting for the two defective TPMS sensors obtained from the ebay vendor. While the refund was appreciated, it came nowhere near covering the additional labor cost of again having my tire shop remove/replace the defective TPMS sensors. Lesson learned: buy the TPMS sensors from the business that is installing them on your car (not ebay). If I had, I would not have paid any additional fees for their faulty product.
