AC Rapidfire Spark Plug Experiences.
1. Octane boosters do not work.
2. Adding four gallons plus of Union 76, 100 octane gas helps but pricey and inconvenient.
3. Adding four gallons plus of Toluene helps but pricey and inconvenient.
4. C5 radiator is too small IMO but not ready to go the "Be-Cool" route yet.
Solution? Rapidfire spark plugs fixed the detonation. :D
Part #12. Available at Autozone, $32 for 8. Gap is factory set at .060" (C5 specs.)
After inspecting the stock Denso plugs I am amazed what a hot plug this is (heat range). The Rapidfire plugs are colder (shorter insulator).
I found the spark plug installlation easier (driver's side) if you remove the smog pump plumbing at the exhaust manifold. I needed no special tools just a spark plug socket, ratchet, and extensions. Actually the hardest plug to get at was on the pass. side at the firewall (ac lines in the way). Be sure to use Anti-seize compound on the plug threads and silicone dielectric grease on the wire boots. Job took me one hour.
In summary I am convinced the AC Rapidfire spark plugs are a good choice for the LS1 (I have tried NGK TR55). Not only did they stop the detonation, the car pulls harder in top RPM compared to the other plugs I have tried. The plugs should last a good 50k miles.
