At witts end with 4l60e leak
Old Sep 18, 2014 | 11:57 PM
77BlueL82's Avatar
77BlueL82
Default At witts end with 4l60e leak
For the past three, yes three years I've been trying to stop a leak on the 4l60e in my 1997.
I've installed a new gasket, pan and bolts. The top and sides of the tranny show no signs of a leak, ie, no fluid. It seems like the fluid is dripping from the front of the tranny on the drivers side. I looked in the hole on the tc cover and it looks dry. I even put my finger and a q-tip and it comes out dry. It only leaks when the car is parked. I think it's leaking when the fluid drains from the convertor back into the pan.
Has anyone had the same issue? Does anyone have any ideas? Please, please, I going nuts!!!!
Old Sep 19, 2014 | 06:23 AM
Cutlassmaster's Avatar
Cutlassmaster
Is it leaking from the drive selector shaft just above the pan? Pic's would also be helpful.
Chris
Old Sep 19, 2014 | 09:28 AM
Smoken1's Avatar
Smoken1
Chris
Had to replace one on a 2000 there is a tool to remove and reinstall the new seal
Old Sep 19, 2014 | 02:29 PM
77BlueL82's Avatar
77BlueL82
Cutlassmaster, Smokin1, thanks for the reply. Next week I'll borrow my friends lift and check that seal out. Hopefully that's the problem. I'll post pics.
To At witts end with 4l60e leak
