real cover install
Old Sep 23, 2014 | 08:58 AM
Blow Torch's Avatar
Blow Torch
Default real cover install
Swapping out my rear engine cover to stop a small leak while my trans is out. Do you have to have the "install tool" they recommend to install the cover (with seal already installed in cover) onto the engine?
There are supposivly two lips (one in, one out) that have to be acclimated correctly, and this "tool" does that.
Old Sep 23, 2014 | 12:52 PM
feeder82's Avatar
feeder82
Yes without the alignment tool you will be doing it again, its critical on the rear cover.
Old Sep 23, 2014 | 01:09 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
I agree.. Dont SKIMP on that part.
Bill
Old Sep 23, 2014 | 02:55 PM
Blow Torch's Avatar
Blow Torch
Where do I get this tool???
Do you think a parts store might rent one?
Keep in mind; I have a NEW cover with the seal already installed in it, so the tool that installs the seal AFTER you put the cover on, won't work
Old Sep 23, 2014 | 06:45 PM
Chris Stewart's Avatar
Chris Stewart
Have to say I've never used an alignment tool and never had a leak. Replaced the seal itself and the covers several times. When installing the cover, let it locate itself on the crank or balancer in front, and snug it down.
Old Sep 23, 2014 | 06:52 PM
Smoken1's Avatar
Smoken1
Here is where you can get them
http://www.saccitycorvette.com/Timin...nmenttool.html
Old Sep 23, 2014 | 07:28 PM
Blow Torch's Avatar
Blow Torch
Originally Posted by Smoken1
Looking at the video, the tool is used to center the cover without the seal, then INSTALL the seal. My seal is already installed..
Chris
Did you have to use a pick or something to pull out the seal? I don't have it with me, but someone posted that the seal has two lips; one facing in and one facing out, and one of them wants to fold under during installation
Old Sep 23, 2014 | 08:41 PM
Chris Stewart
It goes on pretty easy. I never had any concern of losing its shape. Honestly I don't see how you could mess this up, and I'm the king of do overs lol.
Old Sep 24, 2014 | 09:50 AM
Blow Torch's Avatar
Blow Torch
I guess it's from reading several different post that say if you don't use the "tool" it WILL leak. Since it's leaking slightly now, it sort of has me concerned I guess.
Old Sep 24, 2014 | 10:22 AM
StingrayRebel's Avatar
StingrayRebel
I would definitely get the tool to make sure it's centered properly... you can try to eyeball it but it would suck to have to pull the drivetrain back out for a small leak that could have been prevented... you might have to buy a new seal so you can remove the one on your cover, install the cover, then install the new seal... my seal was a real pita to get out, I had to use a screwdriver and hammer to get it to start coming out then there is a tab on the front side of the cover that you can fit a flathead in and pry the seal out... just be careful because it is soft aluminum... I did my rear cover with the saccitycorvette tool and it's dry as a bone, before they started offering their tools (which are much cheaper than most others btw) I had previously done my front cover gasket and used the balancer to align the seal... well it has a leak and now I'm having to go back in and fix that but I will be doing it the proper way this time and it's a good excuse to upgrade balancers and add a secondary drive
Old Sep 24, 2014 | 07:13 PM
Blow Torch's Avatar
Blow Torch
I may have to just try and install it. I am installing the trans this Sat., and I don't have time to get a "tool set" and cant imagine pulling out a brand new seal. I will just take my time and try to get it right.....
Old Sep 24, 2014 | 10:36 PM
dr_whigham's Avatar
dr_whigham
Agreed here. I've done it several times myself, different motors, all H/C/I cars and never a leak or issue.
I'll add I only replaced the seal itself as well. I do what you do. Let the crank snout or the rear center it, then hand thread the bolts in allowing the cover itself to center, then torque bolts to spec.
Old Sep 24, 2014 | 10:38 PM
lionelhutz's Avatar
lionelhutz
I'd agree with the others. If you're skipping the tool then let the seal center itself and then carefully snug the bolts so they don't move the cover.
To real cover install
