Rear defogger wire came off
Old Sep 24, 2014 | 07:18 PM
jjaaam's Avatar
jjaaam
Default Rear defogger wire came off
Anyone else have an issue with the rear defogger wires breaking off at the tab?
The tab is still soldered well to the window. It looks like over time the wire itself had flexed so much that it broke off where it was crimped onto the window tab.
Soldering this would be a PITA as the window would be a huge heat sink...
Has anyone run into this before? How about the Permatex defogger adhesive? I was thinking that I could glue the wire to the tab then tape the crap out of it (neatly of course)...anyone ever use that stuff?
Looks like the other side might be breaking soon too so I want to get 'em fixed.
Thanks...
Old Sep 24, 2014 | 09:15 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
That stuff is made to repair individual grids, not for strength or handling a lot of current.
Old Sep 24, 2014 | 09:29 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You can use a razor blade and "carefully" cut/split the tab off.
Repair the tab by soldering a new one on the wire and use the product below to adhear it back on the window:
http://www.ebay.com/itm/CRL-Loctite-Rear-Window-Defogger-Tab-Adhesive-Repair-Kit-Electrically-Conductive-/261475794678?_trksid=p2054897.l4275
Thats what the OEM joint is.
That reminds me. The one on my Wrangler broke a few months ago. I will be doing the same repair.
Bill
Old Sep 24, 2014 | 10:12 PM
jjaaam's Avatar
jjaaam
CRL Loctite Rear Window Defogger Tab Adhesive Repair Kit Electrically Conductive | eBay
Bill
1. The tabs on mine have the wire crimped in it. Do you mean reattach the wire by soldering it to the old tab?
2. Not crazy about the razor blade. Won't I be risking cutting the grid?
3. It looked like it was soldered onto the window. It's not? It's the Loctite?
Old Sep 24, 2014 | 10:54 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you can take a picture and host it to a hosting site like PHOTOBUCKET and post it, I can get a better idea on making the best procedure to repair it.
Bill
Old Sep 29, 2014 | 09:25 AM
jjaaam's Avatar
jjaaam
Bill
Fixed...for now.
I bought one of the Permatex EC adhesive kits and glued the wire right to the tab. Seems to be holding...and it works.
We'll see how long it lasts...
Old Sep 29, 2014 | 10:14 AM
Sox-Fan's Avatar
Sox-Fan
The wire attachment tab broke off of the square plate on my car while cleaning the window a while back . Took it to a glass company and they were able to carefully lift that square (which is only glued on it seems) and glue a new one in place. Defogger works just fine and you cannot tell from looking at it that it was not original.
Two of the big chain glass companies told me that I need a new window at the cost of $1300 when I called. The smaller local glass company that I called said they keep the copper squares in stock and change them all the time. Sometimes it works, sometimes not, no guarantee, but I wouldn't be in worse shape than I was. I drove on over and took the chance. It worked. cost: $75. time to fix it: 15 minutes. "Your car was a lot easier than most" he said.
By the way, he very! carefully! lifted the tab off the glass with a hard plastic spatula.
To Rear defogger wire came off
