traction contol issue
Old Sep 28, 2014 | 02:31 PM
jimtackett's Avatar
jimtackett
Default traction contol issue
well my 98 has a issue..at 35-40 mph the traction control active warning comes on and it takes car down to 15-20 mph before the trottle comes back on..i have cleaned the ignition swith as was advised to do on here and it reads good with volt ohm meter...checked the codes and got NO CODES...now im lost...any ideas?? tire size is 275-40-17 front and 315-35-17 on rear..please help..thanks jim.
Old Sep 28, 2014 | 02:35 PM
Corvette_Ed's Avatar
Corvette_Ed
Have you checked your wheel speed sensors and associated wiring?
Old Sep 28, 2014 | 08:10 PM
jimtackett's Avatar
jimtackett
no i have not..how do i do that???
Old Sep 28, 2014 | 11:38 PM
BigGun's Avatar
BigGun
It is your tire size causing the problem. You have to keep rear at least half inch larger outside diameter to avoid problems. You can always just switch the traction control off until you get the tire situation straight.
Old Sep 29, 2014 | 10:42 AM
c5vetteguy's Avatar
c5vetteguy
2018 C5 of Year Finalist
Your front and rear tires have the same diameter of 25.7".
Just curious as to why you're running 17" wheels in the back, unless they're for drag racing.
Old Sep 29, 2014 | 10:53 AM
Corvette_Ed
I missed this the first time. This would definitely do it.
Old Sep 29, 2014 | 07:49 PM
jimtackett's Avatar
jimtackett
just bought the car thats what was on it...this is my first vette dont really know much about them...
Old Sep 30, 2014 | 01:02 AM
BigGun's Avatar
BigGun
Stock is 17 on the front and 18 on the back. A few people run 18 all around but have to be careful of the tire sizes. Remember it is the tire size that matters and not the wheel. I run 265\35\18 on the front and 305\30\19 rear. If you buy new wheels be sure you get the correct C5 backspacing.
To traction contol issue
