Need help with idle problem
Old Oct 2, 2014 | 09:25 AM
flynhi's Avatar
flynhi
Default Need help with idle problem
My 99 has had an occasional idle/dieing problem that is getting worse.
Over the past couple of years, the engine will die at idle - sometimes when cold, sometimes when hot. Usually it clears up and idles normally after driving a couple of miles.
This has been happening more frequently and yesterday it died nine time while exiting a parking garage. Then it cleared after driving a mile or so.
The car just had a minor tune up by very experienced Corvette mechanics that did not reveal any vacuum leaks. No codes are being shown and no Check Engine Light shows. I cleaned all grounds about a year ago. The ECU has a custom tune that is otherwise great so I don't think it is a MAP problem.
Any ideas as to why this is happening will e welcome.
Old Oct 2, 2014 | 09:57 AM
Corvette_Ed's Avatar
Corvette_Ed
Clean your MAF and TB, and make sure you aren't getting any unmetered air behind the MAF.
Old Oct 2, 2014 | 10:41 AM
flynhi's Avatar
flynhi
Thanks Ed
The 99 has been converted to Speed Density so it has no MAF.
TB appears clean. Not shiny clean but not gummy.
Old Oct 2, 2014 | 11:24 AM
Corvette_Ed
Originally Posted by flynhi
Thanks Ed
Give it a good cleaning anyway. You'd be surprised at how much just a little bit of gunk can change things. If it persists I'd start looking at the vacuum lines.
Old Oct 2, 2014 | 08:18 PM
flynhi's Avatar
flynhi
Hi Ed
I cleaned the throttle body as you suggested. It wasn't to bad in front of the blade but filthy behind. Idle is much better now. Thanks for the tip.
Does this mean that the inside of the intake manifold is as dirty as the backside of the throttle body? If so, how do I clean it up?
Thanks again.
Old Oct 3, 2014 | 08:05 AM
Corvette_Ed
Hi Ed
Thanks again.
I'm glad that helped. I don't know about the intake; someone with more knowledge than I have will have to answer that question for you. I've never taken my intake off.
Old Oct 3, 2014 | 12:35 PM
flynhi's Avatar
flynhi
Would Seafoam clean the inside of the intake manifold?
Old Oct 3, 2014 | 01:49 PM
Corvette_Ed
That's a very good question. Hopefully one of the more knowledgeable members can answer it for us, because I really don't know. I've never seen an intake off of the engine so I don't know how things flow inside of one.
To Need help with idle problem
