Homelink
I want Homelink in my C5 Z06.
I have the option to send my visor to a guy who installs Homelink in the visor much like is offered on the C6. His reputation is solid and comments about his work are excellent. It costs about $90 including shipping and works with rolling codes found on new garage door openers. Turn around time on the job is a day or two, so this is a great option and looks as original when done as it does on a C6 from the factory.
Before I do this, I am interested in knowing if anyone has installed Homelink in their C5 by replacing the rear view mirror with an after market with auto dim and Homelink. This is another option and I want to check on its availability. If not possible, I will send my visor. If someone out there has replaced the rear view mirror with an after market model with auto dim and Homelink - please let me know.
DILLI1
DILLI1
I have a homelink in each visor I put in myself and bought this mirror with GPS and rear view camera from China to amuse myself.
I'm going to mock it up working in the car before installing it but get a glass shop to do the removal and mounting.
http://www.ebay.com/itm/261359819743?_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
The Homelink mirror itself is 75.00 new
http://www.ebay.com/itm/BRAND-NEW-GENTEX-GENK41-REAR-VIEW-MIRROR-KIT-AUTO-DIMMING-HOMELINK-/261615650886?pt=Motors_Car_Truck_Parts_Accessories&hash=item3ce9820846&vxp=mtr
https://www.corvetteforum.com/forums...-rearview.html
http://i20.photobucket.com/albums/b2...os/Gentex1.jpg
http://i20.photobucket.com/albums/b2...os/Gentex2.jpg
http://i20.photobucket.com/albums/b2...os/Gentex3.jpg
http://i20.photobucket.com/albums/b2...rrorWiring.gif
Edited to add that I no longer have the map lights. There is a way to wire these in, but I never got around to it since it does involve opening the mirror and wiring them in for power and a switch. I don't drive at night all that often and never really had a need to use these lights. Maybe once or twice over a few years, but that's what my cellphone flashlight app is for!
I only need a positive and negative.
The rest of the mirror has it's own harness.
DILLI1
But this location is ideal for me only if it worked!!
who is this guy? got a link? i'd like to get mine done too.
If your motor is newer than above, you have too many codes programmed. (when your memory is full, the circuit board will delete one of the existing remotes to make room for the new one) To rectify this, get all of the remotes that you own, and bring them to the garage where they will be accessible. Follow the antenna to the motor, press and hold the learn button until the LED goes out. (you have erased all of the memory)
