Help with fuel problem
Old Oct 6, 2014 | 05:45 AM
Dave concrete's Avatar
Dave concrete
Default Help with fuel problem
So tonight on the way home car was running fine then 5 minutes from my house car just dies. Zero pressure on gauge. Just in case I put in two gallons to verify fuel gauge is good didn't help, checked fuses and relay they check out fine. So could it be the fuel pump? Anyway of checking without dropping tanks? Car has 26k on it and fuel pump was replaced thru warranty on crossover repair so maybe 5k on it.
Old Oct 6, 2014 | 05:19 PM
dadaroo's Avatar
dadaroo
You posted in General also. Where do you want us to respond?
Old Oct 7, 2014 | 05:48 AM
Dave concrete
I know but I had little response originally so this is why I moved it over here as well
To Help with fuel problem
