Do i need a tune?
Old Oct 7, 2014 | 11:13 AM
johnnyzvette's Avatar
johnnyzvette
Default Do i need a tune?
02 Z06- stock motor-
I recently added LT headers w/o cats. I was under the impression that a tune was not required, the computer would adjust to the changes. I'm experiencing some hesitation and bucking from the car shortly after start up, sometimes it even stalls but after about three minutes of doing this it clears up and seems to run fine. Btw, it idles just fine. Do i just need to get the car tuned or do i have another issue?
Edit Reply
Old Oct 7, 2014 | 11:35 AM
HmnRcn's Avatar
HmnRcn
You may not NEED a tune, but sounds like you should invest in one. It will really bring out the power you tried to bolt on with the headers. Check out the ECS Mail order tune for only $149! Did this to my slightly modded C5 and it really brought the car to life.
Old Oct 7, 2014 | 11:51 AM
johnnyzvette
Ok, i will pull codes and post later. I'm not with the car at the moment.
Old Oct 7, 2014 | 12:06 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Premium Supporting Vendor
From: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
cat codes, a tune is required IMHO.
Old Oct 7, 2014 | 01:36 PM
Gordy M's Avatar
Gordy M
You have made some major changes to the motor and the PCM cannot fully adjust to those changes without a tune. The engineers programmed an adaptive strategy into the computer and you made changes that are not covered in this strategy, that is why the tune is required. Like Doug said, the removal of the cats changed so many parameters you are experiencing such as acel, decel, idle, etc.
Old Oct 7, 2014 | 08:51 PM
johnnyzvette
Originally Posted by 8VETTE7
Have you tried pulling the codes to see if they have anything interesting to tell???
Here is how to pull and post codes:
OR
http://www.c5forum.com/ayc/dtcdic.php
Post ALL your codes including the H or C or HC that follows each 5 character code. If you have any Unnnn codes then list the sensor under which the Unnnn code appears. For example 28-TCS U1016.
The same Unnnn codes can appear under multiple sensors and it is helpful to know which sensor the Unnnn code is associated with.
Here are the codes I pulled:
28 TCS C1287 HC
C1288HC
40 BCM U1096H
58 SDM U1096H
60 IPC B0521H
80 Radio U1096H
99 HVAC U1096H
BO RFA U1096H
Old Oct 7, 2014 | 09:15 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
Did you do anything else along with the headers? CAI maybe? Did you remove the plugs when you installed the headers? It's easy to crack one if left in during install.
Definitely get the mail order tune! It'll be $150 well spent.
Old Oct 8, 2014 | 05:37 AM
johnnyzvette
The only other mod i did is the zip tie mod to the air intake.
I already replaced plugs and wires.
I will do the tune first and see it that helps. I have had more than one person say i need to get it tuned.
Old Oct 9, 2014 | 07:24 AM
johnnyzvette
Ecm is on its way to you Doug, thanks!
Old Oct 9, 2014 | 12:41 PM
Nate@VanBortelChevy's Avatar
Nate@VanBortelChevy
Platinum Supporting Dealership
I highly recommend a tune. The computer does adjust the fueling but only so much and not as accurate as you'd like.
Old Oct 9, 2014 | 02:52 PM
DOUG @ ECS's Avatar
DOUG @ ECS
Thanks!
To Do i need a tune?
