How much to replace my battery???
Old Jul 31, 2002 | 09:15 PM
primetime's Avatar
primetime
Default How much to replace my battery???
Part two..posted this question earlier but if you didnt see it, I think I need to get a new battery...How much should I expect to pay for a new one????? Any type of brand I should go with as well????? They tough to remove as well???? thanks for all your help! :chevy :) :cheers:
Old Jul 31, 2002 | 09:28 PM
Xssesive's Avatar
Xssesive
Default Re: How much to replace my battery??? (primetime)
Do a search and you will get a lot of posts about this. Having said that most of the guys use the OPTIMA red top or the GM gel type. Having researched this I think i will go with the Duralast, which is the no 1 in consumer reports and use a battery matt under it as insurance in case of a leak. The mats are only $5 through Ecklers or Mid America. Battery install is easy, need to disconnect negative terminal first and make sure everything is off to prevent sparking possibility. :yesnod:
Old Jul 31, 2002 | 09:31 PM
Old Rotor Head's Avatar
Old Rotor Head
Just had mine replaced by dealer. AC Delco gel (warranty)$140.00.
Old Jul 31, 2002 | 10:15 PM
Xssesive's Avatar
Xssesive
Default Re: How much to replace my battery??? (Old Rotor Head)
THAT'S TO HIGH! You can buy a Duralast for $70 with more cranking amps and better warranty. :smash:
Old Jul 31, 2002 | 11:00 PM
Fang S-289's Avatar
Fang S-289
If you have a COSTCO near you, the Optima Red Top can be had for $115.00 the last time I was there. I think the price at Pep Brothers, Interstate etc. is $130.00. No danger of acid leakage and very high CCA.
Old Jul 31, 2002 | 11:45 PM
luvinc5's Avatar
luvinc5
Default Re: How much to replace my battery??? (Fang S-289)
I bought the Optima Red Top from LAPD for $110, delivered to my door the next day.
Old Aug 1, 2002 | 04:06 PM
I too bought an Optima Red Top from L.A.P.D. for $110 shipped to my door. This was at the end of last year. Check with Shawn at L.A.P.D. to see what specials they are offering.
Old Aug 1, 2002 | 04:54 PM
Tom/99's Avatar
Tom/99
Costco had the Optima red top batteries for $ 99.00 this past Sunday.
[Modified by Tom/99, 2:55 PM 8/1/2002]
Old Aug 1, 2002 | 05:11 PM
COOL Z06's Avatar
COOL Z06
Default Re: How much to replace my battery??? (luvinc5)
:cheers:
Another satisfied L.A.P.D. customer!! :yesnod: :D
Old Aug 2, 2002 | 10:48 AM
carpe dm's Avatar
carpe dm
Optima Red top at Costco for $99. When you buy, be sure to get a "gel" or "glass mat" type to eliminate the potential leak problem. :smash: :yesnod:
To How much to replace my battery???
