rear shock bolt nut plate snapped off help!
Old Oct 16, 2014 | 03:33 PM
Macbeth2853's Avatar
Macbeth2853
Default rear shock bolt nut plate snapped off help!
So I found bad bushings on my right rear shock on my 2001 z06 and decided to change them out. Upon reinstalling the shocks and securing them with the bolts one of the bolts got a little snug then the nut plate popped off. I got the nut plate off the bolt and removed them. It looks like it was tack welded in 3 spots but 2 out of the three didn't bond and the last one finally snapped. Does anyone have a decent solution to my problem? Thanks in advance.
Old Oct 16, 2014 | 03:48 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Can you post a picture of your broken part?? It will help us point you in the correct direction.
You have to host all photos thru a hoisting site I.e. Photobucket Its free for minimum band width.
Bill
Old Oct 16, 2014 | 05:06 PM
Macbeth2853
Hopefully this link works I just created it.
http://s1376.photobucket.com/user/Ma...e2da8.jpg.html
Old Oct 16, 2014 | 05:51 PM
4DRUSH's Avatar
4DRUSH
What the hell is a nut plate
Old Oct 16, 2014 | 05:59 PM
Macbeth2853
It's a flat piece of metal that also has a tube like appearance in the center of the metal that is internally threaded and has two small holes for rivets. Sorry for the aircraft terminology. It's basically a welded nut I'm talking about.
Old Oct 16, 2014 | 06:19 PM
4DRUSH's Avatar
4DRUSH
Show us what you're calling a nut plate in here
http://www.c5forum.com/diy/shocks.php
Old Oct 16, 2014 | 06:30 PM
Macbeth2853
Removal Procedure (Rear)
The first figure where in shows the upper bolts going in. The bolts go up into the plate and into a nut on the other side of the plate. The pictures on my photo bucket shows the picture of the tack welded nut that those bolts thread into.
Old Oct 16, 2014 | 07:13 PM
4DRUSH's Avatar
4DRUSH
So the nut broke off behind the shock mounting tower?
Completely gone?
Old Oct 16, 2014 | 07:15 PM
Macbeth2853
Yes, in the photobucket link it shows the nut that broke off that had the tack welds on it.
Old Oct 16, 2014 | 07:28 PM
4DRUSH's Avatar
4DRUSH
That link didn't work for me
Clink on the IMG box next to your pic on PB
That will save the link, then press Ctrl & V to paste the link here
Old Oct 16, 2014 | 07:35 PM
4DRUSH's Avatar
4DRUSH
What you could do (besides welding a nut back on) is drill a hole in the rear compartment above the shock tower. (This is what you need to do for coilover shocks for top adjustment) either spin a nut on the shock bolt from the hole or drop the bolt down & install nut from below.
Old Oct 16, 2014 | 07:58 PM
Macbeth2853
I wouldnt mind having it rewelded the only problem is i dont think its possible to do with the limited space in there. When you say rear you mean the opposite side of the side you're looking at when you remove a shock? If so how do you go about it?
Also i fixed the link above so you should be able to view the pictures
Old Oct 16, 2014 | 08:14 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
This is what I have done in the past. That area is accessable via a small space above the bracket. Ive had MICE build a nest in that space.
Clean the area up, clean the nut with sand paper. Use some JB Weld Two Part EPOXY and glue the nut in place. Once the epoxy cures, run a tap up thru the threads to make sure no epoxy got in the threads.
All the blind nut is for is so the factory doesnt have to get a wrench in that area.
Its worked for me in the pas on my JEEP.
Old Oct 16, 2014 | 08:24 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
LOL
You are LUCKY the entire bracket didnt break off the frame. It has happened in the past. That said, you could grind it off, have the nut welded to the bracket and weld it back on.
Old Oct 16, 2014 | 08:26 PM
4DRUSH's Avatar
4DRUSH
To weld it back in- drill holes around the center hole
Place new nut behind, weld through the holes on to the nut
To Jerry rig- follow these instructions on where to drill hole in rear deck for access behind the shock tower
http://www.pfadtracing.com/blog/wp-c...ns-12-7-10.pdf
Old Oct 16, 2014 | 08:44 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Another great Idea If yiou have access to or can borrow a welder. MIG welders are pretty easy to get or borrow.
BC
Old Oct 17, 2014 | 04:50 PM
Macbeth2853
Thanks for the input guys! I think I am going to go the mig welder route!!
To rear shock bolt nut plate snapped off help!
