Steering Column Lock Problems
Old Aug 1, 2002 | 04:48 PM
Oldtoynut's Avatar
Oldtoynut
2nd Gear
Default Steering Column Lock Problems
I just checked with my favorite Chevy dealer Vette tech. Any 6 speed C5 that has had the Column Lock Recall done can be fixed as follows:
Disconnect the CL as described in the CLB instructions with the motor running and MAKE SURE the CL UNLOCKED. The result is a disabled CL. You will get a DIC message "Service Steering Column" each time you start but just hit reset and go on your way. No adverse effects occur. My 99 is fixed!!
Good luck!
Old Aug 2, 2002 | 10:53 AM
carpe dm's Avatar
carpe dm
Default Re: Steering Column Lock Problems (Oldtoynut)
This may work, but I wonder what ramifications it might have; i.e., BCM contacts? :confused:
Old Aug 3, 2002 | 11:21 AM
Oldtoynut's Avatar
Oldtoynut
2nd Gear
Default Re: Steering Column Lock Problems (carpe dm)
I asked the Vette tech that specific question and he said no problem.
To Steering Column Lock Problems
