High Beams Not Working
Old Nov 1, 2014 | 11:56 PM
Sengdemund's Avatar
Sengdemund
Default High Beams Not Working
Completed the HID switch with new housings and installed HIR highs in place of the OEM highs. Now only, one side of my high beams will fire (passenger side).
Bulbs have been checked, wiring harness has been checked and I even bypassed the HID harness and pluged the OEM connector into the bulb with negative results. Pretty lost.
I searched, but is there a specific fuse/relay/etc I may have blown during the install? It's pretty puzzling because nothing is really touched with the high beams during this. They did work before.
Old Nov 2, 2014 | 09:10 AM
Bullymp's Avatar
Bullymp
Check the fuse.I believe it is listed as (HB) high beam.
Old Nov 2, 2014 | 09:13 AM
dadaroo's Avatar
dadaroo
Your owners manual should show engine fuse box fuse #12 is for the driver side high beams.
Old Nov 2, 2014 | 01:04 PM
Sengdemund's Avatar
Sengdemund
Wow, I'm dumb.
High beam fuse #12. Blown, changed, fixed issue.
Imagine that. Thanks for the help.
Old Nov 3, 2014 | 06:46 AM
dadaroo's Avatar
dadaroo
Glad it was simple.
To High Beams Not Working
