Low oil level light
Old Nov 3, 2014 | 02:33 PM
radar502's Avatar
radar502
Default Low oil level light
04 Z0-6 61,000 miles stock .Oil light off on off on makeing me crazzzzy 6.5 Qts in the motor..Anybody got anything new on the fix for this ...Thanks ...
Old Nov 3, 2014 | 05:49 PM
mike venth's Avatar
mike venth
mike v
Veteran: Marine Corps
Default Try this first....
Originally Posted by radar502
04 Z0-6 61,000 miles stock .Oil light off on off on makeing me crazzzzy 6.5 Qts in the mot or..Anybody got anything new on the fix for this ...Thanks ...
Having the same problem(01 Base) first thing to check is the connection
at the Low Oil Sensor. According to BC this is most likely the problem.
The female ends on the plug need to be re-bent to tighten up the male to female connection. Also check the ground at the buss bar on the fire-wall
(passenger side) . Bill says to use the push / pull test on the connectors.
My problem is "the light only comes on when I sit on level ground????
If I park nose up hill or with the car -passenger side lower it goes out, so I'm just learning to live with it...(8 qts of oil) no help.
Old Nov 3, 2014 | 06:26 PM
mike venth's Avatar
mike venth
mike v
8VETTE7, used your info before and all was good, but inspected and cleaned all again.
Got the sensor from O'Reilly's,,, life time warranty. I will be changing Oil next couple weeks
so will change it (low oil sensor) at the same time. GOT ME crazy.. uphill passenger side lower--NO light-- 8 qts oil.. go figure A..
Old Nov 3, 2014 | 07:01 PM
Dcollins3208's Avatar
Dcollins3208
Originally Posted by 8VETTE7
Usually the wiring or plug on the end of the wiring is damaged, or loose. On rare occasions the sensor itself will go bad. On cars with headers it is not uncommon for the heat from the headers to fry the wiring and/or connector.
Yup, my wires were fried by my longtubes
Old Nov 4, 2014 | 09:37 AM
radar502's Avatar
radar502
Thanks for all the info I didn't know were to start I do now OMG I'm going in..I do have long tubes .I have read all the other stuff on this never heard of the longtube deal ... This started about 6-8 weeks back ..Thanks... love the Forum for all the help.. Will let you know what I find...Thanks...
Old Feb 10, 2015 | 01:15 PM
radar502's Avatar
radar502
Well not this time I can see were this can happen.. Fixed: replaced valve covers with Holly ones in doing so broke a ground and lots of rewireing and checking to find the ground that was brocken and after a day of OMG what pain to deal with fixed that then test drive NO MORE LOW OIL DEAL ..I guess was lose or something I checked all the wires and and conctors looking for the bad ground that fixed it somehow ..I have wraped heat stuff around the wires by the headers to try to help with the heat just maybe that will help ,lot's heat and nothing on the wires to stop it from cooking them all wraped now..Thanks for all the input on this ..
To Low oil level light
