Spec on bulb inside the foglight/trunk release switch
Old Nov 5, 2014 | 09:52 PM
Bluemill's Avatar
Bluemill
Default Spec on bulb inside the foglight/trunk release switch
First night driving my car home from work after the time change and I notice 2 dash bulbs out. The Climate control again... only did about 2 years ago, and the one that illuminates the fog light/trunk release switch. The latter is easy to pull, did, and found a neo wedge bulb, with a blue rubbery coating on it, a size T4, with a 10 mm base, and it's 12 mm high.
I found a readily obtainable Honda T4 bulb, but it's dimmer, so it must be a higher voltage. What's the best course of action on this?
The Chevy dealer had no part available. My car is a 2000.
Best,
Bluemill
Old Nov 6, 2014 | 05:41 AM
jamieo's Avatar
jamieo
PM me your address and I will send you one
