Why do we need CCW wheels to get slicks?
Old Aug 2, 2002 | 11:09 AM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Why do we need CCW wheels to get slicks?
If the CCW drag package is $2k, why is everyone running CCW's? It seems like if you could get the backspacing correct, you could get Centerline or Weld to fit you with some rims for a lot less. The numbers dont add up...
Old Aug 2, 2002 | 12:38 PM
2001C5's Avatar
2001C5
Cruise-In II Veteran
Default Re: Why do we need CCW wheels to get slicks? (ICULUKN-C5)
I don't think you are goign to find a weld or centerline with the correct spacing for the front. They would need huge offest to clear the calipers.
Old Aug 2, 2002 | 02:45 PM
kromberg's Avatar
kromberg
I am running a Centerline 16x9.5 with a 7.0" backspacing on the rears. The Lower control arms needed to grinded a little, but the fit just find. Unfortunately, they do not make a skinny for the fronts :(
Keith
Old Aug 2, 2002 | 05:27 PM
ICULUKN-C5's Avatar
ICULUKN-C5
Default Re: Why do we need CCW wheels to get slicks? (kromberg)
So what you are telling me is that CCW is the only company that makes rims for our cars without moding the suspension?
Old Aug 2, 2002 | 05:51 PM
kromberg's Avatar
kromberg
There are a couple others out there, but they still charge about $1700 to $2300 for the set. It is the whole lack of demand thing why the price is so high :(
Keith
Old Aug 2, 2002 | 08:32 PM
Power Shifter's Avatar
Power Shifter
I was under the impresion you still needed to do a little grinding with the CCW. I also understand you can use early 16" C4 9 1/2" rims or F-body 16" 9" if the grinding doesen't bother you. The CCW's are Very nice looking wheels if the price doesen't put you off. The grinding is what put's me off. If there were a 16" rim that would fit with no suspention changes, I would love the extra traction.Anyone know of one? Ric
Old Aug 2, 2002 | 09:10 PM
racewheel's Avatar
0racewheel
Former Vendor
Default Re: Why do we need CCW wheels to get slicks? (Power Shifter)
the contour of the inner rim shell is what is special, and at this time only a 3-piece wheel is going to have the clearence (anything else will have to thick a cross section to give the needed inner diameter dimension). unfortunatley, modular wheels are fairly expensive to produce and the production cost of a 16x5.5 front isn't much different than that of an 18x11.5, admittedly the wheels are overkill for a drag race application, being built from road race components, but it's really to only way to make the fittment work.
as far as the grinding goes, on the 9.5" rear setup grinding is reduced to tapping down ( i've done it with a craftman 1/2" drive ratchet extention because i didn have a hammer available to me at the track) of the cap on top of the upper ball joint. the 10" rear setup does require more than that, but it's still not to bad to deal with and is nothing compared to what is neccesary to make others fit.
hope this clears some things up
Old Aug 3, 2002 | 12:55 AM
Mopar Jimmy's Avatar
Mopar Jimmy
From: Elmhurst, IL (West Suburb of Chicago) & Home of MEGA Horsepower
St. Jude Donor '06
Default Re: Why do we need CCW wheels to get slicks? (racewheel)
John Da Man, no doubt! :smash:
Nitrovette :cheers:
Old Aug 3, 2002 | 08:55 AM
Slammed Vette's Avatar
Slammed Vette
Cruise-In III Veteran
Default Re: Why do we need CCW wheels to get slicks? (Nitrovette)
I'm with you Nitro!!!!John is the man!!!!
Old Aug 3, 2002 | 06:02 PM
Austrian Vette's Avatar
Austrian Vette
Default Re: Why do we need CCW wheels to get slicks? (Slammed Vette)
:yesnod:
To Why do we need CCW wheels to get slicks?
