c5 guys on E85...OEM fuel pump.....failures???
Old Nov 15, 2014 | 12:28 AM
SVT_Z06's Avatar
SVT_Z06
Default c5 guys on E85...OEM fuel pump.....failures???
I heard of failing fuel pumps in C6 vetts on E85, and was wondering if there were any C5 failures.
And how long have you E85 guys been running this fuel.
Thanks!
Old Nov 15, 2014 | 01:33 AM
All_Motor_C5LS6's Avatar
All_Motor_C5LS6
I've been running a 20% mix since 2011.
Old Nov 15, 2014 | 08:03 AM
Joshboody's Avatar
Joshboody
I'm on 50% mix for maybe 6mo. Curious as well with others experiences.
Old Nov 15, 2014 | 03:17 PM
Dnealy's Avatar
Dnealy
Mixing E85 with 93? hmmm. I know they do "Up to 10%" here at the pumps in SC but i didn't think mixing it at an even higher % would be any real benefit because of the extra amount of fuel it takes.
Old Nov 15, 2014 | 04:38 PM
Joshboody's Avatar
Joshboody
It works very well if you need octane. I have crappy 91, so for me to keep a decent timing curve it's necessary. Even without needing octane, ethanol adds VE and will make more HP than gasoline.
A tune is required though for high mixtures.
Old Nov 17, 2014 | 11:07 PM
SVT_Z06's Avatar
SVT_Z06
Cool. Thanks for the replies, everyone.
I've been running an E85 mix on and off for around 6 months. I just filled up and there was a notice on the pumps stating that they raised the prices because of an "ethanol" shortage; a couple cents less than 91. Hopefully it will come down soon.
I enjoy the extra torque, hp, and cleaning properties of E85. Cleaning carbon deposits off pistons and rings sounds good to me.
Old Jul 22, 2015 | 12:22 PM
SVT_Z06's Avatar
SVT_Z06
Bump for updates.
Old Jul 22, 2015 | 12:29 PM
robz's Avatar
robz
For those mixing, it sounds like a pain to keep track of the percentage.
When you say 20% do you mean 20% e 85 and 80% 92 octane?
Old Jul 22, 2015 | 12:30 PM
bluestreak63's Avatar
bluestreak63
You shouldn't be running E85 (flex fuel) period. These engines were not designed to run E85. Now if you're running 93/94 octane (91 if 93/94 isn't available) with 10% ethanol added, that's a different story. And that should be fine.
But there are separate pumps at the stations that carry E85.
Old Jul 22, 2015 | 01:17 PM
Macleod52's Avatar
Macleod52
Old Jul 22, 2015 | 03:56 PM
VGLNTE1's Avatar
VGLNTE1
St. Jude Donor '14-'15
Considering 85 is never 85 and if you are mixing just whatever, you could have a broken piston in the future. Careful with that tune and timing!!
Old Jul 22, 2015 | 04:32 PM
Johnny wangwang's Avatar
Johnny wangwang
Alot of cars were not designed to run E85 or E100 or Ewhatever. But that doesnt mean that E85 cant be run/mixed and isnt the best pump fuel out there for going fast!
I guess people fear what they dont know.
Old Jul 22, 2015 | 04:56 PM
bluestreak63
What's there to fear from not knowing? The engineers who designed the Corvette's engine didn't design it for E85. Sure, it might have higher octane and might be cheaper, but that doesn't mean there won't be side effects to using it.
There are other Chevrolet vehicles whose engines were designed to use E85 if available...the Corvette engine is not one of them.
But by all means use it, it's a free country...
https://en.wikipedia.org/wiki/E85
Corrosion in non-E85 fuel systems
Fuel systems and engines not designed or modified to use E85 may experience increased wear and may fail prematurely. Some (particularly older) fuel systems and those used in powersports and agricultural engines contain rubber seal elements which have excellent gasoline resistance but poor ethanol resistance. These systems generally can accept up to E10 without major degradation in service life of susceptible seal components.
Old Jul 22, 2015 | 05:03 PM
My Vette Life's Avatar
My Vette Life
Thanks!
OK so I only use 91 she'll brand and decided to try 89 and noticed the gas gauge not moving and here I am thinking wow I got way better mileage.
BTW I was on the freeway but until I came to a dead stop, the gauge went down more than what it normally would for the distance I drove.
That was the first and last time for lower grade gas.
I'm in so cal and prefer high grade. I do notice and feel a difference just like changing spark plugs with different gaps.
Old Jul 22, 2015 | 06:10 PM
VGLNTE1's Avatar
VGLNTE1
The only reason cars can't use 85 is because its not tuned for it, or have the fuel system. Otherwise it's better in everyday. For any ls motor. I'd have it in a heartbeat if the c5 was flex fuel capable like the c6 ecu is.
Old Jul 23, 2015 | 09:38 AM
Johnny wangwang
Thanks!
Basically what you need to know is that there probably haven't been any failures. Because most people who run E85 know that you need about 30% more fuel at the same level. So that means you need bigger injectors, a bigger fuel pump, and also tuning to get the wonderful benifits of E85.
Im pretty sure our fuel systems were developed to be up to the task of running Ethanlol. I think after a certain year all cars switched to fuel systems that wont fall apart with ethanol. The motor is a basic piston motor. You can run whatever fuel you want. It just needs to be tuned for it. Ethanol will not make your motor fall apart when used correctly.
The benifits of ethanol are awesome. Your water temps even drop a little! With boost its the only fuel I would run unless you just dont have it around you like that.
Old Jul 24, 2015 | 08:29 AM
dadaroo's Avatar
dadaroo
GM issued a notice on the C5 to warn against using E85. They only endorse a 10% ethanol blend.
For your reading pleasure, the GM notice:
https://www.dropbox.com/s/v2m5v0fbq4...otice.pdf?dl=0
Do as you want.
To c5 guys on E85...OEM fuel pump.....failures???
