1999 C5 Corvette Active Handling Warming Up code C1283
Had a new 408 with an A&A system installed when I picked the car up it has a active handling warming up on the display. Signed it off to the choppy road that I did a big burnout on causing it. Trailered the car home and went for a drive. Within the first 1/2 mile same code came on.... I have done some looking into this and most guys have a problem with the rack or wheel moving when removed or re-installed. I have tested the voltage output of the steering wheel position sensor and am a little baffled. I figured it would be an easy fix by re clocking the wheel to the rack but I have a very strange voltage reading. Some times the light blue wire on the SWPS (light blue closest to the middle of the connector) reads 0.665 volts if you barely move the steering wheel it jumps to around 11.0v. From what I found going straight should be between 2.3-2.7 volts.
I unplugged the connector to the SWPS and tested power wondering if I had an internally shorted sensor.
The 5v ref wire (brown) was good and the 12v wire (green i think) was good but I also had full battery voltage the light blue signal wire which should be at 0 i would think since it is the signal wire from the sensor.... At this point all I can think is a pinched harness supplying voltage to the signal not letting the wheel and rack sync.. Has anyone had a similar issue or an ABS wiring diagram I could get? I have gone over all the grounds and connections I could find but I know these are a little troublesome and have multiple grounds.
The steering wheel must have moved during the motor install. normal readings are 0v to 4.5v with 2.5 being centered. Since you are at .6v disconnect the steering wheel at the motor and rotate it 630 deg to the right. attach it and then take another reading. If that doesn't help try turning it back 2 turns to the left. It has been years since I had that problem and forgot which direction to turn it when it is less than 2.5v. HTH
I think it is kind of my last options here. I will give it a try and if no success then I suppose its time to replace the steering wheel sensor. Just seems like very strange timing for a sensor failure but I guess its possible.
The think about the voltage that is puzzling is you can read it at .6v then barely move the wheel and it goes to 11.8v...... I will follow up with what I find tomorrow thank you for the input!
I found a wiring diagram of the system and re tested everything.
On wheel position sensor:
Pin 1 - I have 5v
Pin 2 - Checked and it has good ground
Pin 3 - It has 11.3v plugged in and unplugged from the sensor
Pin 4 - It has 11.3v plugged in and unplugged from the sensor
Pin 5 is blank on mine- no wire
Pin 6 - has only .05v on analog signal wire.
I did some checking around and figured this was my problem and was told to jump the 5v power from pin #1 to pin 6 when I did I had a hard code c1288 which I had not seen before and the description said "both a and b phase are greater than 4.9v for 1.6 seconds. I un jumped them and the code did not return but my c1283 came back upon test drive.
I don't know if my EBCM is bad or what.... Anyone want to take a few minutes and see what the pins read on a car with no issues???
