Crazy Alarm
Old Dec 1, 2014 | 02:41 PM
RichardBumpus's Avatar
RichardBumpus
Default Crazy Alarm
My 2003 Anniversary Edition's alarm goes off when there has been no attempt to defile my princess. It may go 3 to 4 weeks before it goes off and it may blast every 30 minutes. My temporary fix is to go into DIC and turn off the lights and then pulled the fuse for the horn. I've Googled the issue, but none of their circumstances are similar to mine (other than going off). The battery is fully charged, nothing is wet, it happens even when the fob is a half a mile away. Suggestions?
Old Dec 1, 2014 | 02:58 PM
65GGvert's Avatar
65GGvert
Maybe you've got the same situation as another post on here a few days ago where the neighbors fob for a non-Corvette was setting off his "panic" function intermittently. One other possibility would be that your door switch may be showing the door coming open when it's not, I guess. If it did it more often, you could leave the doors unlocked so as not to arm the alarm and see if it still goes off. If so, it's receiving a signal to set off the panic sound. If it only happens with the doors locked, it's associated with the security portion.
Old Dec 2, 2014 | 11:53 AM
opel's Avatar
opel
My alarm problem was from a weak battery. Check you battery volts should be 12.5 or more.
Old Dec 2, 2014 | 02:23 PM
RichardBumpus
Default Alarm
Battery is at 12.85Vdc. Where are the alarm sensors located besides the door switches?
Old Dec 2, 2014 | 04:11 PM
strand rider's Avatar
strand rider
hope this is an easy problem to fix.
I have some bad habits and tend to put off non essential repairs until I feel like working them out. If you share my style I can provide some extra motivation to attend to this small problem more quickly, like a jockey with a whip, if the true experience below is helpful.
I don't know how you park your ride, but I used to live in an area dense with apartments. An unknown neighbor left for a long week end and their car alarm failed, it sounded and would not go off. The police were called, I don't know exactly why they were unable to help, but they said they were powerless. That car had a good battery, because it didn't let up. After days and nights of solid alarm, the car fell silent, but didn't look too good when I walked down past the car and checked it out. It was covered with eggs that had been thrown, generously , and a side window was broken. I don't know if the window was to shut off the alarm, or just general bad sportsmanship, but I wouldn't want your corvette to get close to that kind of thing, I think egg damage can be real bad once the protein cooks in the sun. You scared straight now kid? ( a small attempt at humor)
Old Dec 3, 2014 | 11:02 AM
dadaroo's Avatar
dadaroo
Not at home now but the door switch for the alarm (and door open chime) is in the latch. I helped someone who had a switch issue that would cause the chime to sound when the door was actually closed. As a temp fix I gave him info on which pin to pull in the A-pillar or at the BCM. That easier than removing the door panel in the short term.
If you want to try that so you bypass the switch to trick the system to think the door is always closed I can provide the info. You could do one door at a time to see if one of them may be the cause.
I hope it is not a random act of "kindness" from the BCM in the sleep mode.
Old Dec 4, 2014 | 08:22 AM
RichardBumpus
I take it the alarm sensors are only in the doors. I'll start working on them. Thanks to everyone who gave their advice.
Old Dec 4, 2014 | 08:38 AM
65GGvert's Avatar
65GGvert
It's not really "alarm" sensors. It's the door open sensors that think the door is open when it shouldn't be. I'm not convinced from your info that the sensors are causing your problem. You said sometimes it blasts for 30 minutes. The alarm resets before that. Is it a steady horn blast, or honks with flashing lights? If steady, you may have the fairly common horn membrane problem. If the other, you may be picking up a frequency that just happens to match your "panic" button frequency on your fob.
Old Dec 4, 2014 | 09:31 AM
dadaroo's Avatar
dadaroo
I don't think the door switches are the issue but I wanted to provide the info. Horn membrane is a good possibility. I have heard of the horn going off just due to temperature changes with a bad membrane.
Old Dec 4, 2014 | 01:42 PM
RichardBumpus
The horn membrane was replaced 2 months ago. I just remembered (old timers disease) the right door was replaced at the same time as the horn membrane. I think I need to take a closer look at that door. I just didn't know if there were sensors other than the doors.
Old Dec 4, 2014 | 04:18 PM
Corvette_Ed's Avatar
Corvette_Ed
Something similar to this happened on an '03 Monte Carlo that I used to own. The only fix for it was to replace the entire airbag assembly as it was the airbag cover contracting in the cold that was setting the horn off.
Old Dec 4, 2014 | 05:42 PM
65GGvert's Avatar
65GGvert
Originally Posted by Corvette_Ed
Something similar to this happened on an '03 Monte Carlo that I used to own. The only fix for it was to replace the entire airbag assembly as it was the airbag cover contracting in the cold that was setting the alarm off.
Set off the horn.
Old Dec 5, 2014 | 11:33 AM
RichardBumpus
I said the alarm may blast every 30 minutes, not blast for 30 minutes. It is not a constant on, but the alarm type on-off, then resets.
Old Dec 5, 2014 | 12:44 PM
65GGvert's Avatar
65GGvert
Definitely sounds like the alarm. A stray signal wouldn't cause the alarm to go off like that, it could trigger the "panic" function though. If the alarm sounds when the car isn't locked, I think the panic function is being activated, either by external signal or a malfunction in the car's computers. If it only happens when the door is locked, it could be either alarm or panic.
Old Dec 8, 2014 | 05:30 PM
Corvette_Ed
Set off the horn.
Correct, the horn. Thank you for catching that typo; I was thinking one thing and typing another.
To Crazy Alarm
