EBCM issues?
Old Dec 4, 2014 | 08:25 PM
Charlie P's Avatar
Charlie P
Default EBCM issues?
Any EBCM issues on 2001-2004 ZO6 models thx in advance also thx 8VETTE7 for your help
Old Dec 4, 2014 | 10:10 PM
donald4972's Avatar
donald4972
St. Jude Donor '14-'15
Not sure exactly what you are asking. If you have a problem with the EBCM, pull your codes from the DIC. And then, very knowledgeable guys here will be able to help you diagnose your issue (s).
Don
Old Dec 5, 2014 | 06:06 AM
Charlie P's Avatar
Charlie P
Don
1997-2000 EBCMgenerally we're not repairable is it the same for 2001-2004 Z06 models or did GM correct the problem
Old Dec 5, 2014 | 08:06 AM
Smoken1's Avatar
Smoken1
Yes they did make some improvements to the 01 and newer. I have had mine repaired.
Old Dec 5, 2014 | 09:17 AM
donald4972's Avatar
donald4972
Call Brandon at ABSFixer . com. He can tell you which codes can be fixed. And, what upgrades to EBCM are available. It is quite a few, actually.
Had mine repaired, and it was a somewhat uncommon code. So, he can repair more than just what (codes) is listed on his website.
Good luck,
Don
Old Dec 5, 2014 | 09:26 AM
Cybermind's Avatar
Cybermind
You may not ever see an EBCM failure depending on how you drive your car. EBCM failures tend to be higher with cars where the ABS/active handling systems are never activated.
But if it should fail and you do not want to dish out the big bucks for a new unit, there are refurbished EBCM's available for 2001-2004 model years at about $300 or so. Much cheaper than new units and will probably last the life of the car due to the upgraded components that refurbished units get. Most also come with anywhere from 5 years to lifetime guarantee depending on who you buy them from.
Old Dec 5, 2014 | 09:51 AM
Charlie P's Avatar
Charlie P
Thank you for the fast response guys very helpful have a good day,Charlie
Old Dec 5, 2014 | 10:46 AM
dadaroo's Avatar
dadaroo
Just so you know an EBCM problem will not affect normal braking. You can actually remove it and still drive the car. You will not of course not have ABS, TC, and AH (if your car is so equipped).
To EBCM issues?
