Weld RTs Back space?
Old Dec 4, 2014 | 10:08 PM
NukeC5's Avatar
NukeC5
Default Weld RTs Back space?
As many of you know, I did LG spindles and 15x10 Weld RTs S71's in the rear. I finally did the rear brake conversion to the front and am going to order the fronts. Im Doing 15x4 and looking at the 2.50" Back space option because Ive heard people complain about them sticking out. This should bring it in as much as possible. But my concern is, do I need to worry about the inside hitting the spindle or anything? The same size comes in a few different back space options, all of which are less. Does anyone have experience with which is the proper choice? I would like to go with the 2.50" BS. I doubt it will be an issue. But need to make sure before pulling the trigger.
