Drivetrain Work
Old Dec 7, 2014 | 07:04 PM
Burkdog62's Avatar
Burkdog62
Default Drivetrain Work
Hey all:
I'm planning on dropping my drivetrain this spring to have the tranny and TT rebuilt by Rick Kim and also will be replacing the slave cylinder and adding a Tick master cylinder and remote bleeder. My question is during my research I've seen some info about shimming the slave cylinder, when is this required? I'm unfamiliar why it's necessary, just looking for some info not too much found during searches.
Also this is the first time I've ever dropped the drivetrain but I've gathered up the service manual as well as a bunch of the write ups on the forum.
If there is anybody local to me who's done this before and who'd be willing to lend some tech help I'd appreciate it and will donate a couple cold ones. Located in Central PA.
Old Dec 7, 2014 | 09:25 PM
martysauto's Avatar
martysauto
St. Jude Donor '14
Google this.
shimming c5 slave cylinder
You'll find a lot of info. The search engine on the forum doesn't work as well as google's.
Old Dec 8, 2014 | 05:01 PM
Burkdog62's Avatar
Burkdog62
Will do thanks for the heads up
Old Dec 8, 2014 | 08:57 PM
Burkdog62's Avatar
Burkdog62
So I read some of the info online and is it safe to say that as long as I'm not installing a new clutch I don't need to deal with shimming the slave cylinder?
Old Dec 8, 2014 | 09:01 PM
dr_whigham's Avatar
dr_whigham
http://ls1tech.com/forums/manual-tra...need-shim.html
There's good info in there
Old Dec 9, 2014 | 12:32 AM
StingrayRebel's Avatar
StingrayRebel
what clutch do you have now?... if it's stock and you are already taking the drivetrain out it would be crazy not to get a good aftermarket clutch in my opinion
Old Dec 9, 2014 | 05:37 PM
Burkdog62's Avatar
Burkdog62
It has a Spec stage 1 clutch currently in it, still in very good shape so I wasn't planning on swapping it out.
Old Dec 11, 2014 | 07:34 PM
Burkdog62's Avatar
Burkdog62
Sounds like when I drop everything I'll make sure I don't misplace the spec shim already in place.
Old Dec 13, 2014 | 01:41 PM
Burkdog62's Avatar
Burkdog62
Thanks to those who have pointed me in the right direction, i do have a follow up question. I was reading a thread on LS1 Tech about this:
Excuse my ignorance but are these measurements taken while the drivetrain is out of the car? I imagine they could I'm just checking since I've never done this before.
To Drivetrain Work
